How do I remove rimguard beet juice?
/ How do I remove rimguard beet juice? #1
Skeletor
Gold Member
Massey Ferguson 1725mb
I’m changing out my tires and my rears have rim guard in them. I pulled out the valve core and I got maybe 6-7 gallons out extremely slowly. I ended up taking the wheel off the tractor and laying it flat on the forks and putting a ratchet strap around it to squeeze it to drain the juice faster. It was miserably slow and there’s still a few gallons in there I bet. It got dark outside so I had to put it back in the tractor and put it away. I haven’t even touched the other side yet.
I have no desire to reuse the rim guard. I’ll use washer fluid or antifreeze. Rim guard is a pita if you have any tire issues it gets everywhere. It also gums up your air chucks if you get any inside.
Any suggestions on how to speed this up? Thanks, mike
/ How do I remove rimguard beet juice? #2
Break the bead if you are not trying to save the rim guard and dump it out.
/ How do I remove rimguard beet juice? #3
Break the bead then insert one of those battery transfer pumps for short money at Harbor Freight. Most likely the beet juice will clog the pump but since they are so cheap I would write it off.
/ How do I remove rimguard beet juice? #4
Smart man. The stuff is disgusting, gross, smelly slime.
You know you see people saying it’s the best thing ever on YouTube. Then you gotta deal with it. It’s pretty terrible to mess with.
I suppose I could lift the tractor up with the outriggers take the rear tires off then break the bead with the backhoe.
Anyone know what steel or iron weights I can put on this thing? It’s a Massey 1725.
/ How do I remove rimguard beet juice? #7
Beet Juice is non-toxic, biodegradable, water soluble,
It's liquid sugar. Break the beads and stuff a garden hose in to flush it out. Pick a place where you don't mind a quantity of sugar water.
I just found a plastic covered concrete set on fb. Their pretty beat up but weight 75 pounds each and he only wants 40 bucks. He said all 12” rims have the same bolt pattern for those.
/ How do I remove rimguard beet juice? #10
I’d probably rinse it out with a garden hose, as long as its not super cold
/ How do I remove rimguard beet juice? #11
From what I see antifreeze is 9.4 pounds per gallon. Beet juice is 11 pounds per gallon.
I've heard of beet juice fermenting causing problems, increasing pressure. Antifreeze is exposed to rubber in vehicles all the time.
I'd go with antifreeze and just eat more pancakes.
Oh there’s no way that beet juice crap is going in my new tires. I had r14s put in the front and was waiting for some good weather to get the beet juice outta the rears. Tomorrow looks like a crap day so hopefully Sunday.
/ How do I remove rimguard beet juice? #15
I guess it would really depend on my location. Beet juice if I was up north. Water with washer fluid will work down here.
/ How do I remove rimguard beet juice? #16
I have thought about buying some sugar in bulk and making a syrup solution of 2 parts sugar and one part water by using hot water. I know this will remain liquid at room temperature but I don't know what the freezing temperature is. I also don't know where to buy the cheapest sugar and if it would be cheap enough, cheaper than non-toxic anti-freeze is where I live. Since I live on an island I will need to add liquid myself or else transport my tires a long way to get them filled. My local Les Schwab will fill my tires with their liquid, but it weighs almost exactly the same as water and costs more than 4 bucks per gallon. There must be some place that sells cheap sugar in 100 pound sacks in the Puget Sound region. Then I can maybe plan a sightseeing trip and pick up a couple sacks. When I get new tires I can then fill them too.
Eric
/ How do I remove rimguard beet juice? #17
Well, a quick look online says that a 2 parts sugar, 1 part water solution will start to freeze at 12.5 degrees F. The coldest we get here on the south end of Whidbey Island is about 15 degrees F. And that is rare and only for a few hours. So methinks a 2:1 sugar:water solution might work well. I still need to know the weight. It looks like a 2:1 solution weighs 11 pounds per gallon. Water weighs about 8.3 pounds per gallon. That's a significant increase in weight. I don't know if the solution gets down to 15 degrees if any of the sugar will come out of solution and if it does if it will go back into solution when the water gets warm and is agitated. What if it doesn't? Or takes a long time to dissolve? Will sugar crystals abrade the inside of my tire and rim? Will it sound like I have a slushy inside my tire? Will this make me nostalgic for hot summer days in my teen years? Should I quit typing?
Eric
/ How do I remove rimguard beet juice? #19
/ How do I remove rimguard beet juice? #20
Antifreeze is approximate 8.5 ,it is mostly water which is 8.34 pounds per gallon
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
New Holland 3930 (A60462)
New Holland 3930...
KMC 216-18' HEAVY DUTY ROTOTILLER (A62130)
KMC 216-18' HEAVY...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59910)
2007 FREIGHTLINER...
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
2016 Ford Transit Connect Cargo Van (A61568)
2016 Ford Transit...
