Tractor tire swing
/ Tractor tire swing #1
tower59
Texas
Hi, guys. Not sure exactly where this goes, but I have an old tractor tire that I'd like to turn into a giant tire swing. You know the kind- with the tire parallel to the ground. Anyone out there done this with a big tire? Any suggestions? Is it too big for the kids to use? Thanks for any help with this project!
/ Tractor tire swing #2
Sounds cool! But it might be hard for a kid to stop when it got moving.
Knock somebody down also!! JMO
DAVID,
/ Tractor tire swing #3
DAVID,
Yeah, tractor tires are heavy! Also, the center opening (where the wheel mounts) might be a bit big for a kid who would enjoy swinging.
/ Tractor tire swing #4
my elementry school had the best playground ever till they tore it down cause if splinters
that one had pee gravel the new one has mulch
but it had a giant tire swing and it was kinda low to the ground and the amount of swing was limited, and they attached threaded i bolts like you might see on some power lines with the threads in side the tire so there were no sharp edges on the out side
wish i had pictures now
/ Tractor tire swing #5
You need to put 3 eye bolts evenly spaced in 3 locations around the tire ... a length of chain from each (any length suitable to you) to a swivel and a ring and one chain to the tree branch of choice...
And enjoy !!!
/ Tractor tire swing #6
Make sure you drill a hole in the bottom of the tire so that rain water will drain out............
/ Tractor tire swing #7
Just drill 3 holes 120 degrees apart and run a rope through the holes figure 8 knot under it to haul rope.
Drill 3 more hoes on the bottom for drain (you never know were the low spt will be.
My kids had one and loved it!
tom
/ Tractor tire swing #8
do you tie a figure 8 at each of the top holes or do you weave the rope through them and tie 1 figure8?
/ Tractor tire swing #9
I spliced 3 lines to one at the top and the 8's were in the tire to make it so I could level it.
tom
/ Tractor tire swing #10
Growing up, my neighborhood park had one in it's playground. It was big enough for 5 kids to sit in at a time. It was heavy enough that we could not swing it very far, but it was on a heavy swivel mount and we loved using it like a merry-go-round. Everyone would hang on to the chains for dear life as we spun it around on that swivel. :thumbsup: I would not use a fixed bolt or rope to hang it, the twisting would just break that connection.
2021 John Deere 1025R (A60462)
2021 John Deere...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
1660 (A59213)
1660 (A59213)
