Tractor Stuck
/ Tractor Stuck #1
Shemp
Trying to push out an old tree that had fallen and since the ground is a little soft the back tires started sinking in. Either way I went it would just go deeper. Didn't have my shovel to try and dig it out so I will have to try it tomorrow. Anyone with some helpful info would be greatly apprieated. Thanks.
/ Tractor Stuck #2
How about chaining a fence post to a rear tire, engage differential lock and have at it. If enough chain, then soften the rear tire and get it to wrap in the middle of the rim. Drop the 3pt arms to level of the drawbar, add a ring to the drawbar with the chain thru it, other end of chain in a ground anchor, when you pull up the lift arms the tractor will be pulled out.
Call a neighbor and make friends for life.
/ Tractor Stuck #3
The fence post trick will work, but is a last resort.
I would dig a gradual ramp out and dig out all the humps of dirt from behind the front / rear tires. If you can, jack up the wheels and slide a 2x6 under them to keep from sinking more. More work, but less potential down sides.
Hot tip, when you think you've dug enough and are ready to try it. Take a 15 min break and then come back and dig / prep with boards and what not for an extra 30-60 minutes. If you get antsie and try when it's not ready you will be that much closer to setting the belly on the ground and that's a whole lot more digging!
jb
/ Tractor Stuck #4
an old off-roader technique used prior to nylon tow straps, and it works very well. It relies upon the inertial momentum of the towing mass just like a "snatch" strap, as opposed to raw traction or horsepower, and it applies zero shock load to either vehicle.
You will need 2 chains, with a total combined length capable of reaching from the towing to the towed vehicle, and 1 old used tire(no rim). Attach #1 chain to the stuck vehicle and to the tire. Attach #2 chain to the towing vehicle and the tire. The finished setup goes chain-tire-chain.
The chains and tire will look like this:
Towed []----------O-----------[] Towing
Once all is attached, with a driver in both vehicles, the towing vehicle simply drives away accelerating to about 5 -10 mph.
The elasticity of the tire smoothly transfers inertial force to the towed vehicle and out you come. The tire absorbs all of the shock load. Disclaimer: Non-essential people stand clear.
/ Tractor Stuck #5
Shemp:
Welcome to TBN :D! Many of us have gotten ourselves stuck myself included (more than once :mad: :(). We do not have any information as to what type of tractor you have and what accesories. Do you have a FEL and/or a back hoe? You could use these to claw/curl your way back out. You could use a come-a-long attached to a solid object or a large danforth type anchor. The other posters offer other possible solutions and I am sure more will come. Good luck- Jay :)
/ Tractor Stuck #6
Welcome to TBN Shemp. :)
Will you frontend loader lift the front tires off the ground enough to get something under the tires...will save you alot of digging...might have to dig and jack the rear up and fill the ruts,than slowly try going backward and curling the bucket outward,for that little extra push.
/ Tractor Stuck
I do have a FEL on it. I've heard of the claw/curl way. Haven't seen it done. But it sounds self explanitory. I'm thinking I'll have to take off the cutter to lighten the load a bit on the rearend. Thanks for all the input.
/ Tractor Stuck #8
You might try using the bucket and chain this way. Put the bucket in full dump, attach chain routing it under lip of bucket and fasten to something behind you, then as you back up curl the bucket, has gotten me out several times and the curl function of most loaders is pretty strong.
/ Tractor Stuck #9
I use the FEL to get unstuck pretty often, although sometimes when i push the loader down into the mud suction is created, then when i try to pull the loader out of the mud it just pushes the front end down in the mud more. dont know if that makes any sense
/ Tractor Stuck
Well I got her out! Alot of digging and the FEL came into play but she came out. Tried using the FEL to push backwards but it was stuck with mud up to the differential on the rear axil. Used the FEL to pull forward and was finally abel to get out. Now she needs a good washing. Thanks for all of the input.
/ Tractor Stuck #11
Shemp:
Good for you :D! I have been quite creative in how I have gotten stuck in mud in the past :rolleyes:. Jay
/ Tractor Stuck #12
Shemp, don't forget to pay special attention to the wheel bearings when you wash it down. Just like any car, they can get fouled with gunk and sieze up. I'm sure you don't want to replace one in the field!
/ Tractor Stuck #13
The whole secret of getting out is having a solid anchor point and enough heavy rope or chain to reach it. If your rear rims have holes in them that you can pass the chain thru then you have a built-in winch, even if it is only 4-5' per pull.As the chain wraps down under the tire it will lift as well. Then anchor with the fel, spin the tire forward enough to get slack to reposition the chain on the rim, etc until you have backed onto solid ground
2000 International 4900 Tandem Truck (A66285)
2000 International...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
2014 MACK GRANITE (A65643)
2014 MACK GRANITE...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
