Tractor Flat Prevention Options
/ Tractor Flat Prevention Options #11
Since we were having lots of problems with flats on our RFM we had the 4 tires on it filled with the 2-part foam at a cost of 10 bucks per tire. We are happy with the results, no more flats, period.
/ Tractor Flat Prevention Options #12
Don't forget NOT to get the crummy rubber tire valve inserts, they rip off the hub way too easily. Get the steel valve inserts and preferably the steel welded on rim protectors for the valve.
Getting stuck in the mud or sand or having one ripped off by a branch is a major pain as I found out the other week when it happened to me out in the woods when a branch tore off the entire valve on the right front wheel resulting in an instant flat. Jacking up the front with the FEL was no problem, but if it had been one of the water filled rears I really would have been in trouble. The replacement steel insert only cost $10 installed.
/ Tractor Flat Prevention Options #13
How about going to the welding shop and have them replace those rubber tires with nice steel ones? Ones with big ole spikes would aerate the lawn and garden.
Ralph
/ Tractor Flat Prevention Options #14
Hi there folks...this is one option I can recommend for repairing flats and small holes in your tires. I keep a kit in each of my vehicles and it's saved me lots of hassle and $$$ over the years. For tubeless tires. I am not sure the plugs will work on loaded tires, haven't tried yet. (I think they will, though). I also use the auto kit to do my ATV's, lawnmower, etc. If it's a larger puncture, I thread more than one plug on the tool to make a fatter plug. Haven't tried the heavy equipment plugs.
http://www.safetyseal.com/store/tire.htm
Dave
/ Tractor Flat Prevention Options #15
</font><font color="blue" class="small">( <font color="blue">http://www.arnconet.com/ </font> )</font>
I did a search at the Arnco website above but could not find Quikgel liner for flat prevention. Here's a link on another webpage:
http://www.isserpr.com/quikgel_liners.htm
Arnco Unveils QuikGel™ Self-Sealing Poly Liner to Prevent Punctures on Off-Road Tires
Arnco, the leading supplier of flatproofing products for off-road vehicles, has introduced QuikGel™, a self-sealing polyurethane liner that reduces downtime from flat tires by providing protection from punctures up to ¼” in diameter..........QuikGel is ideal for skid steers, agriculture, telehandlers, golf cars, lawn/garden, ATV and other applications where less weight is needed. ........
2012 HEIL (A60736)
2012 HEIL (A60736)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2005 Freightliner M2 106 Ambulance (A59230)
2005 Freightliner...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
1997 International 4800 4WD S/A Dump Truck (A59230)
1997 International...
