Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,181
Making photos is not allowed in the factory.
And we work quite differently with pre-bent steel, using welding clamps to let them follow contour, will not work with the 12mm upwards sheet thicknesses we work with, thats why im very interested in the solutions Bfreaky comes up with 😉👍👍👍
Talking about bending solutions...10 tone bottle jack did it...;)
/ Tractor backhoe - homemade #1,183
I'm wondering why not use an oxy/acetylene torch to heat the metal in the area of the bend & then bend it? There is probably some advantage in stress reduction & weld penetration as well.
rScotty
Ou that's simple...because I don't have a torch :)
/ Tractor backhoe - homemade #1,185
Stick some double folded heavy grit sandpaper under the jack for a bit of traction.
It did not slide because it's hooked at the right spot. Plate went down without problems. There are no new pictures because last few days I'm only heavy welding those booms
/ Tractor backhoe - homemade #1,187
I was the only one wondering why the strap didn't break while jacking, guess I'm the only one that Murphy helps.
I've put a round thick metal plate on top of the cylinder so it could not pierce the strap
Heavy welding boom no 2.
/ Tractor backhoe - homemade #1,190
This heavy flat welding would be a good place for 5/32 7024.
/ Tractor backhoe - homemade #1,191
My day job is maintenance of electronic equipment at a factory. It has little or no connection to this but...this is what I really like to do and would love to do as a primary job...perhaps some day when I have enough $ to start my own buisness
Firstly, I would like to say how much I enjoyed this thread and how awestruck I am at your skill set and how you turn your thoughts into reality in steel .
Secondly, I think you are overlooking a huge income stream that is at your fingertips . If you were to design attachments and put them into digital format, we could purchase your plans and have the components Laser/Plasma cut and all we would need to do is weld them together and source cylinders etc .
There are tens of thousands of people like us here who would buy your plans, potentially millions of dollars .
I seriously think you should put some thought into it .
Congrats, there should be a TBN award for the effort, planning and attention to detail you put into your backhoe build . :thumbsup:
/ Tractor backhoe - homemade #1,193
Very nice work on the hoe arms! Back in the day I ran a boring bar machining parts like that and the pivot points had solid slugs welded in place. We would use a large saw cutter to machine between the bosses then drill/bore the pivot pin holes in-line. Will there be final machining or is the OP going to line-up finished pin bosses then weld them in place? Interesting thread that brings back great memories!
Eagleview, I appreciate your words, thank you. Well I could make cad files but I don't know your laws so I'm gonna have to look into it...
Ruffdog, the plan is to weld already machined bushings into place with pins inside so they line them up. I'm aware it's better to use line boring to get perfect results but I still don't have line boring machine
First two are at 90%, but I just could not resist putting them together for the first time just to see the reach...so here it is...
/ Tractor backhoe - homemade #1,197
Wow, looks awesome so far! How many hours do you have invested at this point?
/ Tractor backhoe - homemade #1,199
What kind of controls are you going to have on it? The best option I can think of is something like a telhandler has where you press and hold a button to use a 4 motion joystick to accomplish 6 movements.
I'm not sure, stopped counting hours some time ago. :)
I will use 2 Nimco joysticks with buttons and electromagnetic diverter valves so there will be no foot pedals this time. It's better and faster (and more expensive) this way
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2014 ISUZU NPR 4X2 18FT BOX TRUCK (A59911)
2014 ISUZU NPR 4X2...
Caterpillar 320B/BL/BN/LL Excavator Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
UNUSED WOLVERINE HYD AUGER ADB-13-1218R (A64281)
UNUSED WOLVERINE...
2017 Hino 155 16ft. Box Truck (A61573)
2017 Hino 155...
Caterpillar 970F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 970F...
