Tractor backhoe - homemade
/ Tractor backhoe - homemade
Made some upgrades; joysticks got direct link to distributors because cable control is waay to jumpy for this kind of machine. Also, hydraulic pumps are no longer mounted directly to the PTO shaft, that made coupling a nightmare because both pumps and gearbox weigh 36 kg so I had to lie down and mount it overhead...that's why I changed pump rotation, bpught different type of gearbox and turned it 180 to get some distance to use short cardan shaft.
upload pic
upload pic
Also added block valves to secure outriggers
upload pic
Cab view
upload pic
upload pic
Tractor works at 1200-1300 rpm, backhoe has tandem gear pump 2 x 50 cc/rev, pto works at max 540 rpm, here about 400 rpm. It can go even faster but what's the point, it will only heat oil faster
/ Tractor backhoe - homemade #1,667
Have you used the triple boom adjustment already in a situation where you needed it ?
Yes, all the time. Triple boom is the best decision ever. You can extend it to reach far, and curl it to get as close as possible. Also if you lift something too heavy for your boom cy, 2nd cylinder will help
Close, max power
Reaching into the pit
Operator view
Digging a hole to put all those roots and stumps inside. I have to make a bigger bucket to dig it faster. This is only 400 mm wide(narrow)
Thanks. It works as expected. There is always some space for minor improvements, but I'm satisfied with it as it is.
And finally the last one, probably the biggest...took me half hour and another 15 min to dig a hole big enough to bury it at reasonable depth. The machine passed stress test, if this job didn't break it, nothing will. So now we have some 120 m2 of new clean land.
It's my brothers land, he plans to grow potatoes here because they like this kind of soil
/ Tractor backhoe - homemade #1,676
/ Tractor backhoe - homemade #1,677
0.03 acres, it would be a big garden patch.
Have to to laugh at 0.03-acres being a big garden patch. Grew up on a self sufficient farm outside of Boise. Dad used his GI Bill farm purchase to buy an orchard outside Boise, then built a new farm house, and after the five year limit, subdivided it and paid off the loans. We had a full acre of garden to fill two chest freezers. Every fall, mom would blanch and freeze enough vegetables to fill one freezer, the other one held the meat from a grass fed steer, and a couple of deer.
The grandparents had about an acre and a half in garden. Their ranch was off grid, and grandma, canned every day for a month every fall.
This is not a garden, it's a farm land of 3 acres all together but this last purchased part had some trees and bush on its edge so we just cleared it because there is no point of keeping it.
120 Gallon Tank (A64127)
120 Gallon Tank...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2019 John Deere 6130M (A64126)
2019 John Deere...
Club Car (A59231)
Club Car (A59231)
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
