Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,622
Looking good! Needed a little fabrication pick-me-up this morning! The post outriggers and side shift options are rare over here and sought by foundation repair companies. Excellent work and inspiring craftsmanship.
/ Tractor backhoe - homemade #1,625
Looks real good! How do you like the extra stick on there so far?
Extra stick is the best decision ever. I get great reach with full lifting power. Much better then telescope. In a few days we will test it with jaw bucket, I'll make a video and post it
/ Tractor backhoe - homemade #1,629
That's one impressive bucket. I sure like the way it separates the clamping function from the bucket rotation. Not being able to separate those two motions is the downside of a traditional BH thumb. Your's seems like a better way to do it. I hope you are patenting some of these designs.
Also noticed that the Aux. Hyd. outputs changed sides. And that reminds me that I wanted to ask what your preference was for size and quick connector type. On the JD310 those aux connectors are dash 12 size - which is 5/8" hose and fitting flow diameter. Yours look like a similar size.
rScotty
/ Tractor backhoe - homemade #1,630
That is awesome work! I’m not sure what is patentable though. VAR and clamp buckets already exist and are being sold by other companies.
Yes rScotty, I had to switch sides because my quick hitch pin goes in right to left so those cylinder hose T fittings would be directly in front of the pin.
/ Tractor backhoe - homemade #1,633
For the VAR you have a foot pedal to switch between the cylinders or an automatic setup?
Joystick with buttons, and a em valve at cylinder no 1 and 4
/ Tractor backhoe - homemade #1,635
I've done a number of patents. There's a popular idea that patents only apply to major earth-shaking inventions. Those are wonderful, but that is not the only way it works.
A patent exists to reward a person for publishing an improvement to the old way of doing things. It can be as simple as a lever and pivot..or a new way to polarize glass. But to earn a patent it has to not only be an improvement, it also has to be new and unique i.e. not already in common use. You can't patent a twist-top jar lid just because it never has been patented; it is already in common use.
So the trick is to find something unique about a new design...some unique change you've made to make it better. Just looking at Freaky's work this last decade, it wouldn't surprise me if some of it qualifies. I wouldn't know just what, but he would. Then that change is patentable.
Bottom line is a patent doesn't have to apply to the whole device, any improvement will do.
rScotty
/ Tractor backhoe - homemade #1,636
rScotty
OK.
From my courses the most important thing about a patent is having the lawyers to aggressively litigate against anyone coming close to violating it.
/ Tractor backhoe - homemade #1,637
Does your backhoe run off a single gear pump? The video shows very smooth operation, even with the outriggers up. Nice.
What is an "em" valve?
Hydraulic system is run by 2 hydraulic gear pumps, each with 50 cc/rev and 2 hydraulic valves with 80 liters/minute max flow. Controls are logically divided to achieve maximum productivity, so my left joystick has commands: boom rotation, boom lift/lower and one switch to extend 2nd boom. My right control commands: stick extend/retract, bucket, and switch diverts bucket open/close. EM or electromagnetic flow diverter valve 6/2; 2 lines in, 4 out, switchable with a press of a button on the joystick
Btw, video shows boom reach and movement at half throttle, machine can move about 3 times faster when working when you get used to commands
/ Tractor backhoe - homemade #1,639
OK.
That is certainly a popular modern way to think about the value of a patent - although rather self-serving.
The "patent for profit" motive is a legal and financial interpretation. There is opportunity - but no requirement - for profit in a patent.
Another way would be to consider that a patent provides a convenient standard format for publishing beneficial ideas.
The original idea behind a patent seems to me to be an attempt to blend educational & profit motives.
rScotty
/ Tractor backhoe - homemade #1,640
Did you invent them, or did you file them ?
My development at a previous employer was patented. The patent attorney asked to supply a description, to which he only added periods and commas: I literally wrote the patent. He charged 7000 Euro. AFAIK filing it at the national patent office sets you back only 1000 to 1200 Euro, which is a more realistic fee if it has to come from private savings, instead of from a couple of million in business turnover.
I am now working on a design which will be tested at my mates farm this autumn and spring in secrecy. How does filing a patent work ? That patent attorneys best quality was protecting his own job, the last time i dealt with one, so i dont think they are going to teach this ape how to climb...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2023 Cross Tech Brushwolf Alpha XP 74in. Brush Cutter Skid Steer Attachment (A66734)
2023 Cross Tech...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
2012 INTERSTATE TRAILER 28 T/A GOOSENECK TRAILER (A67714)
2012 INTERSTATE...
2011 GORILLA BUILT MANIFOLD TRAILER (A67714)
2011 GORILLA BUILT...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
