tra vac 854 pto model
/ tra vac 854 pto model #1
logankelly
winona mn
jd2520
Would this model work on a 3 point quick hitch system? Called two trac vac dealers they did not know. Hate to get it and find out it will not work on my Land Pride quick Hitch. It would also extend the pto shaft another 4 inches might not have enough shaft.
/ tra vac 854 pto model #2
The short answer is no, not really-at least for me.
Now, my MMM deck is controlled by the rockshaft lever so the 3PH goes up and down with the deck, so I had to make brackets to hold the weight of the blower while still allowing the 3PH to move freely.
You did not mention what tractor you have? How is the MMM height controlled?
Here are some pictures: https://picasaweb.google.com/113966569709555812037/TracVac854#
/ tra vac 854 pto model #4
Unless you have the independent lift option, you will be in the same boat as me.
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2021 KMC 7406 (A64126)
John Deere 1025R (A62177)
John Deere 1025R...
Rooster Weather Vane (A64127)
Rooster Weather...
(32) Kinze Seed Tubes (A65640)
(32) Kinze Seed...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
