TODAYS SEAT TIME
   / TODAYS SEAT TIME #13,541
Mr. Lou...looks like y'all are pulling in a vintage stock tractor class...
Didn't realize that tricycle WD came stock with that beautiful chrome exhaust stack?!?
Looks like a great day to be out doing it!
   / TODAYS SEAT TIME #13,542
Had a decent day today, a benefit tractor pull just down the road,
My brother took his little WD's down and I ran one of them. He has 2 WD's and my Nephew has a WD and an IH 460 to play with
He pulled in the 3500#, 3 1/2mph, 5 mph and open class, he won in the open and did good in the others, beating his grandson by less then 2 feet in each.
In the 4000# class we both pulled along with his grandson,
In the 3 1/2 mph class all three of use did good a couple ribbons.
in the 5 mph class the tractor I was on did real well, pulled a second place and later we learned the 1st place was DQ'ed for speeding so actually ended up as first,
the others were in the top 5 or so.
Then we got rained out before the 4500# class could pull, I ended up coming home, the others waited it out and finished pull about 5:30 or 6 this evening.
Haven't heard how they fared yet.
My brother,
and the other WD that I pulled,
Afternoon at tractor pulls...yes sir. (y) :)
   / TODAYS SEAT TIME #13,543
It was a hard to find option :)
It's kind of funny for us in several aspects, For me and my brothers a WD was the first tractor we would drive. With the hand clutch to stop we didn't have to reach the clutch pedal or brakes at the same time. I kid him about it his WD45's are older then he is and younger then me, his WD is my age. As new they were at 30-40 HP on the drawbar those have just a tad bit more, his hotter one has almost a half inch of stroke added to the crank with a bit of clearancing, the others have stoke stroke big bore sleeves and a bit more compression then stock.
But those size tractors are relatively inexpensive to buy and hop up a bit and the parts are almost reasonable.
   / TODAYS SEAT TIME #13,544
Another day of rotary cutting,
We FINALLY have everything cut once, and a couple places cut twice, and that's it for rotary cutting, until grows some more. lol
SR
   / TODAYS SEAT TIME #13,546
Just a few minutes today cleaning up the residue from my burn pile in the yard this year;
Used the Branson bucket as back stop and the little Kioti to haul away till just a bit in the big bucket.
All done.
   / TODAYS SEAT TIME #13,548
I picked up a Creek Bank 3 ton dump trailer yesterday and gave it a try this afternoon hauling four loads of soil. The tractor hydraulics had no trouble lifting the bed at idle and the trailer seems to be well balanced while pulling and dumping a load.
After I was done hauling I used the rear blade to give it a rough grade.
   / TODAYS SEAT TIME #13,549
No pictures but I spent the day helping out a good friend and fellow Army Vet (he served in Vietnam) clean up his yard after the severe storms that came through this week. He had several trees come down. I hauled out 4 dump trailer loads of firewood and loaded the rest with of the brush in a 10 yard dumpster. Tractor made quick work of it.
   / TODAYS SEAT TIME #13,550
I finally finished my annual bush-hogging, nocking off the last two fields today (the smallest one and the largest). I cut about 20 acres total each year. Today was a great day for it, cool and windy with no skeeters.
I did one field in the rain yesterday when it was calm, warmer and raining. My canopy top stopped the rain but not the skeeters.
   / TODAYS SEAT TIME #13,552
Are the deerflies biting yet in your area Gordon?
   / TODAYS SEAT TIME #13,553
   / TODAYS SEAT TIME #13,556
Didn't grab any pics but I got my Woodland mills Chipper and spent yesterday cleaning up brush. Made easy work of it!
   / TODAYS SEAT TIME #13,557
About 13 hours added on the tractor hourglass, and counting...
State dumped about 18 Tri-axles of mixed road millings late last summer. Was still building the house then, but have now finally got to the point of putting in the new driveway.
Removed grass and top soil down 8 to 10 inches...scored the ground first with the scarifiers on the box blade, then dug it up with the loader. Mixed clay with some chunk rock - it came up easy with the cutting edge I added to the standard Kubota bucket.
Then put down 12' wide driveway geotextile. The photo shows piles of millings just scattered on the textile. This section is about 18 feet wide.
I had to get it anchored down from the wind ahead of what was left of Beryl passing through Northern PA.
   / TODAYS SEAT TIME #13,558
The millings were mixed...some of it is well ground up, but there are odd shaped chunks about 2 inches thick mixed in.
I picked up a used rock bucket on Marketplace, which I'm using to sift through the millings and separate the chunks from the ground millings.
This is a bit slow, but separating the chunks out makes the end results worth it.
The pile on the left is 99% ground millings. With the larger chunks separated and placed down first, the back and forth of the tractor over the chunks settle and lock in the larger chunks pretty well.
   / TODAYS SEAT TIME #13,559
That's a good stroke of work BackRoad. Keep your driveway pictures goming.
gg
   / TODAYS SEAT TIME #13,560
You can see the cross-section in the below photo with the native ground underneath, the geotextile fabric, the base "large chunk" layer and the initial layer of ground millings.
I still have a top coat to add to this section, but it's turned out way smoother than I thought, even at this stage.
I'll use the landplane with the separated ground up millings for the top coat, to shape the final crown and finish leveling the driveway surface...
About 60% done at this point...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59905)
2005 INTERNATIONAL...
2018 GENIE Z40/23N RT ELECTRIC BOOM LIFT (A60429)
2018 GENIE Z40/23N...
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
