Tires tire repair
/ tire repair #1
Judy_in_NC
North Carolina
Mahindra 3510
I'm hoping someone has a suggestion for me.
One of my front tires (on 3510) has gotten a pretty good size cut into it - fairly deep, though the tire is not losing air. (Don't know when it happened - likely when we were pulling down the walls of an old house we were dismantling.)
I am thinking there should be something I can put into this cut that will set up to a consistency similar to the tire rubber and help prevent dirt, sticks, whatever from poking into the cut and doing more damage. Any suggestions?
Judy in NC
/ tire repair #2
It the cut in one of the treads or into the skin of the tire? I have never heard of anything designed to do something like that. Maybe fill the cut with a good latex adhesive type chalk and let set up before using the tractor. The chalk would remain somewhat flexable once it has set up. Or a automotive adhesive type sealer. But it is a very interesting question. Some one may have the solution to your question. It will be interesting to hear what they are.
Good Luck
/ tire repair #3
Judy
I have the same gouges in my tire(s), I have TITAN tires on my tractor. Don"t have a answer for you but I too would be interested if someone does.
If you post the same question in the parts/repair forum you might get a larger viewing from all TBN members
Ron
/ tire repair #4
Nope. I have never seen anything to fill the outside rubber on a tire.
Only thing I can think of is fill the fronts with foam.
/ tire repair
I'll try posting in the other forum. Thanks for everyone's feedback.
/ tire repair #6
Interesting question and the answer is ..... I've never heard of anything but it's such a common problem you'd think that somebody would make something.
If you think it might be a problem I suppose you could head trouble off by installing a rubber boot on the inside, behind the gouge, install a tube and fill it with Slime. I think that would make it as good as your going to get.
/ tire repair #7
I gouged one of my rear tires on a wire fence panel. I thought the same as you. I went to the auto parts store and found a small tube of rubber adheasive. It is an orange tube and the sealant is black. I filled in the gouge and it needed filling again in about a week. Now it is good to go. It is the color of black tire so it is even hard to find.. I can look in garage and see if I can find it if you need me too.... I think though that if you just go to the Auto parts store and see what all they offer you will find something similar.... Hope this helps ya Judy......
2022 EZ-GO ELITE...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Lincoln Arc Welder (A62613)
Lincoln Arc Welder...
Case IH 800 (A64127)
