Time for Chainsaw Chaps
/ Time for Chainsaw Chaps #121
I've run a saw since I was 15. Never had chaps bud always had earplugs, helmet and gloves. When my stepdad bought a saw he scared the crap out of me when he used it. I bought him and myself chaps and got him up to speed on how to plan out what you cut and how to see what will happen as you cut. 2 pair of chaps is less than what it costs to go to the emergency room. I use mine whenever I saw.
/ Time for Chainsaw Chaps #122
I'm always upset when it takes me so long to "dress' for using the chain saw. First steel toe shoes, then chaps with suspenders to hold them up then long sleeve cowskin leather weldding jacket, then face mask, then goggles, then helmet with face sheild and ear protection. Finally heavy duty work gloves.
But now looking at that I will never complain EVER AGAIN.
I'm just wondering if wearing too much safety gear could be a safety risk due to the inability of quick movement, for example, snagging on something in the woods while making a quick move to get out of the way.
"face mask, then goggles, then helmet with face sheild[sic]" this just sounds to me, over-done.
/ Time for Chainsaw Chaps #123
So true, so true. I've never worn my seat-belt because I'd like to "get out quick" before I'm in an auto accident. :laughing:
/ Time for Chainsaw Chaps #125
If you anticipate or are in a sketchy situation my advice would be DON'T CUT walk away, no tree is worth it.
There are many things to do to prevent the quick get away besides a person will make 100 cuts and need to
make a quick get away one ever 100 cuts. In the mean time all the gear will lessen the odds of something happening
those other 99 cuts.
Also buy gear that fits and gear that is comfortable and that shouldn’t hinder anything.
Think about my steel toe boots are more comfortable than by street shoes.
My chain saw gear does not restrict movement a bit.
Good gloves don't hinder my running away.
My helmet gives me the same peripheral vision as my glasses do so no hinderance there.
Now if a widow maker comes down I don't think it matters if you're wearing safety gear or not
and not many people can run fast enough to clear a widow maker since most won't even
be aware it dropping down on them.
Bottom line, can't wear enough safety gesr in my opinion.
If fact I feel much more relaxed in proper safety gear. No I won't take extra chances I just
feel relaxed that if something goes sideways i'm better protected if not wearing the fear.
My movements are much more fluid and I'm not as skiddish and a lot less stessed when
cutting.
/ Time for Chainsaw Chaps #126
So true, so true. My first jeep didn't have doors or seat belts, i bet i could get out faster than you could. :D
Quite often you are out before you even make that choice. ;) A relative is a paramedic on the LifeFlight air ambulance, he says that Jeep riders are his second best customers. The first are motorcyclists, he calls bikes "donorcycles."
Getting back to chainsaw safety equipment; I doubt that anybody could say it better than CatDriver, just above me. The only thing that I would add is that a comprehensive safety course geared toward your level of expertise is time and money well spent.
/ Time for Chainsaw Chaps #127
Ok 13 pages and I think I need to find an arborist site and get some advice from those guys on specifics
/ Time for Chainsaw Chaps #128
I had been pruning trees for about 13 years, one concept I think is possible, is that any disc that spins, has forces that veer it sideways in another direction (Vector Nature of Rotational Kinematics) Its likely saws have a similar movement. When you're unfamiliar with a saw those forces will be unpredictable. It's after you've cut a log while the chain is still spinning, that's when you're likely to cut yourself, your wrist has limited strength over sideways movement of the bar.
I can think of many electric tools that continue to spin for sometime after, but you need to take the MS200 up a tree, and if I cut myself it'll rain blood, it would be good if Stihl could add a braking feature that quickly idles the chain to remove that dangerous window of opportunity. I've seen hydraulic chainsaws attached to excavators stop instantly, that and kickback where it spins back and hits you in the face.
The first time I was up a tree I had started using my colleagues saw instead. he likes to tweek his saw, it was lucky, I cut my left arm but took off microscopic layers of skin, I couldn't tell I'd been cut, 2 days later about 20 scab wounds started to appear. The second time I was on the ground, I had just fitted a new chain I ordered online and it turned out to be low kickback. A Stihl MS200 will just knaw away at your skin easy.
I had a wound about the size of a cigarette butt. A new chain has an unpredictable veering motion you don't know about and it's way too sharp as well. So a good pair of trousers and long sleeved t shirt. So yeah there's horrible wounds I'm too scared to look at anyone's pictures, it took 12 years of doing it before I cut my leg to realize how bad it was.
/ Time for Chainsaw Chaps #129
I see zero reason to wear the mesh face thing unless it could protect against a facial saw cut. If I am uncomfortable, I will not be as safe in my actions. I will be bothered by the discomfort and immobility and thus be distracted.
I worked in one factory where I had worked before without much safety concern. Now, I had to wear hardhat, goggles and hearing protection. With fork trucks moving around and all kinds of heavy machinery, I felt quite out of touch with my environment and in more danger.
It has also been proven that adding all manner of safety equipment to automobiles has actually made drivers, drive less safely.
/ Time for Chainsaw Chaps #130
The mesh face mask is great when you are cutting overhead. It keeps the chips out of your eyes. Otherwise, I don’t use one.
2019 Bomag BW 211D-5 Single Drum Vibratory Soil Compactor (A59228)
2019 Bomag BW...
Ford 8510 (A53317)
Ford 8510 (A53317)
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
43023 (A59228)
43023 (A59228)
Engine (A59230)
Engine (A59230)
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
