Time for Chainsaw Chaps
/ Time for Chainsaw Chaps #151
No problem. It just seems more and more that people feel that you should do it just the way they do. At the end of the day the objective is to get the job done with no blood loss... rather difficult here right now during black fly season.
/ Time for Chainsaw Chaps #152
Answers to some questions posed here: Washing chaps can make them less effective, (it's detailed in the owner's literature that comes with most brands of chaps), because the safety is in the fibers in the chaps getting caught up in the chain's teeth, and thus stopping the 88 feet /second travel speed of the chain* from doing damage like the op experienced. When washed the fibers tend to mat down vs. being fluffier and the result is less effectiveness. Same with if they get real dirty or greasy/oily.
I noted a number of people in this thread said their accidents or close calls with chainsaw chains occurred when they were tired or too tired.
This is worth paying very close attention to. Using a chain brake when starting, changing location, or position, etc. is a very good, 'best practice' detail that can help prevent serious injuries from chainsaws.
Also, taking frequent breaks in one's work to cool off, drink water to keep hydrated. etc. can keep one's 'situational awareness' at a maximum.
I also try to never work alone with a chainsaw, even for a 'few quick cuts'.
Think about how a chainsaw functions. It is designed to make mincemeat out of wood at a very rapid pace. It turns wood into saw chips instantaneously and thus treats skin and bone the exact same way. It does not discern the difference between wood and flesh.
Because of the type of spacing of chain teeth they cut skin by ripping it to pieces which means that one's chances of bleeding out before making it to the ER are also increased, and that doesn't even take into account the shock factor.
As the OP said, he didn't even know he had cut his knee until he saw the blood.
So, knowing everything one can about how one's saw and it's chain function, knowing best practice handling of the saw, wearing ALL recommended safety gear WHENEVER using a saw, all reduce the likelihood of a catastrophic incident.
Technically, the chainsaw chain should come to a rapid halt on it's own within a few seconds of the trigger being released. If it does not, or continues to run around the bar, then the saw is out of adjustment and needs to be serviced before further use.
One way to stop the chain even faster, aside from applying the chain brake, is to purposefully touch the bar/chain to a piece of wood within easy reach of the saw, using all the necessary precautions against kickback/rollback, etc.
Here's the facts Jack:
From Google inquiry as to speed of a chainsaw's chain~
"The piston ring speed on the average chainsaw travels 2,500 surface feet per minute. A chain slides across the surface of the sawbar rail at around 5000 feet per minute. The chain is moving at 55 to 60 m.p.h. or a mile per minute ( 88 feet per second* ).
One last thing; anyone considering the cost of chaps should seriously consider the cost of a visit to the ER to triage their torn knee, leg, calf, etc. Essentially NO comparison, IMHO.
Here's to the OP~ Sorry for your unfortunate loss to your saw's chain. Thankfully it wasn't worse. Get well soon and be safe in future.:thumbsup:
Coyote said it well.
I got in the habit of using the chain brake and got some chaps when a friend suffered the same injury to his knee. I use them less when bucking wood on the ground as the saw can only go thru the log and hit the ground. And ear plugs work just fine; 33 decibel reduction and I can still be aware of my surroundings. And I like my hardhat. It may not stop injury but it will sure reduce it.
I've been using chainsaws for 40 years and they still scare me.
/ Time for Chainsaw Chaps #153
I have always worn safety glasses and hearing protection when using my chainsaws. I have finally "seen the light" and wear chaps all the time and a helmet most of the time. The helmet has saved a lot of bumps and scrapes on my head as I climb around storm damage and scope out the situation. The only problem I have with the face mesh is forgetting it is there, and then spitting (makes kind of a mess).
Doug in SW IA
/ Time for Chainsaw Chaps #154
Just so everyone knows the saw accident statistics. There are 30,000 per year for chainsaws in the USA and the cuts are located approximately 50% above and below, your belt line.
/ Time for Chainsaw Chaps #157
And if you get into a fencing match!
:laughing:
The only fencing that I've tangled with was barbed wire, and I'm not sure how a screen would have protected my legs. ;)
/ Time for Chainsaw Chaps #158
It happens, safety equipment reduces the severity of injuries. Luckily only the skin. Brought the saw too close to my body before the chain had stopped. Ruined a nice pair of Carharts.
/ Time for Chainsaw Chaps #159
I hate that. The CARHARTS don't heal.
Like a gun, don't put that bar near anything you don't want to cut. Really, how hard is that?
/ Time for Chainsaw Chaps #160
Why it's as easy as a diet! Don't eat more calories than you burn. Really, how hard is that?
....:rolleyes:
(p.s. Guess which "easy one" one kills more people.)
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2015 Ford F-350 Versalift Bucket Truck (A59230)
2015 Ford F-350...
2020 Vermeer Vac-Tron LP873SDT T/A Vacuum Trailer (A59228)
2020 Vermeer...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
2022 Ford F-150 Pickup Truck (A59230)
2022 Ford F-150...
