Timber Frame Build - Round 2
/ Timber Frame Build - Round 2 #281
If there is no movement on the cantilevered walls, it works great. I forget where, but it was suggested that you double up your house wrap under the Hardie. I use half inch Hardie on the walls, over the house wrap and OSB. Then I seal the Hardie edges with Redgard to make it water proof. Some people paint the entire face of the Hardie, but I like the idea of the thinset going directly onto the Hardie and not a layer of Redgard. But from what I'm reading in some of the home building trade magazines that I get, house wrap and tape is being replaced with specialty water proofing membranes like Redgard and applied to the entire exterior sheeting instead of house wrap. Kind of like what Zip System is, but you apply it yourself. They say you get a better seal this way then anything else out there.
Thinset is stronger and sticks better then brick mortar. It's more money, but not that much more. Ardex is the very best brand of thinset, but the regular grey stuff at Home Depot is still my favorite for most things. Use a half inch by half inch notched trowel and work your way up.
Eddie, Hate to rob the OP's page but.... Can I do that same thinset and fake veneer stone over blue board insulation on the outside poured concrete walls? Instead of leaving the concrete exposed and having to insulate the inside of the walk out basement. Thanks, Jon
/ Timber Frame Build - Round 2 #282
Sorry, I have no experience with blueboard. Schlutter is a popular product made of plastic and foam that doesn't have any real strength to it, but relies on the thinset and tile to provide the strength. There are other plastic, Fiberglas sand Styrofoam products out there that are popular too. For decades, sheetrock was used in showers in millions of homes. Some never leaked and are still in use today. If I was you, I would go to a tile supply house and ask them what to use. There are also some very impressive thinset mixtures out there that can do some amazing things. They cost jumps for them, but when it's done, you never have to worry about it. Avoid a carpet type flooring store. Find one that people in the tile trade go to.
/ Timber Frame Build - Round 2 #283
Be interested to see the stone work. I think the lathe and scratchcoat is more of a pain than sticking up the actual stone (which is slow but easy and relaxing work).
One thing I learned putting up stone veneer is to mix the mortar looser than usual, more like oatmeal than peanut butter. I'd dampen the scratchcoat with water from a hand bottle, put a nice head of mortar on the stone, press the stone in place with a light wiggle, hold it with my finger for about 10 seconds, and then move on to the next stone. The suction of the looser mortar is enough to hold the stone in place and those 10 seconds begin the bonding process. It defies logic but it works so much better than using a thick mortar.
I also worked from the top down, to avoid getting any mess on stones below. People tend to work from the bottom up like they are laying brick, but with veneer you can work from the top down (and if the stones are not staying put and sliding or moving, it means you're doing it wrong).
/ Timber Frame Build - Round 2 #284
Always wanted to try sticking fake stone, never got up the nerve to try.
Got a block wall in basement i want to cover.
Never know until you try. It's actually not hard, just time consuming. Until I did the columns for the wedding area I had never done it. As S219 mentioned the key is in the correct moisture content. I'm using real stone so its heavy but if you get the mortar mix right it will stick instantly, you don't even need to hold for more than a second or two.
Stayed up late last night and got the bar covered. A couple little spots I don't really like where too many stones lined up in a straight line but not unhappy enough to pull any back off. I'm planning to head back down later tonight to start running mortar joints.
2018-03-10_04-17-39
/ Timber Frame Build - Round 2 #286
2018-03-10_04-17-39
Looks fantastic... don't obsess over the seams. Only you think you see flaws! :drink:
/ Timber Frame Build - Round 2 #287
2018-03-10_04-17-39
That looks AWESOME! I sure don't see any lines/joints/spacings that would bother me. The first time I put up stone, I was worried I wouldn't be able to make it look random enough, but it wasn't nearly as hard as I thought. It's supposed to look rustic, which gives a lot of freedom (unlike brickwork where you need things to line up). Random with a few surprises thrown in is a good way to think about it.
Great job, and good choice of stone. Looks amazing!
/ Timber Frame Build - Round 2 #289
Installing the rock is the fun part. Doing the grout isn't.
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1998 POLAR TANK (A60736)
1998 POLAR TANK...
John Deere 4600 (A53317)
John Deere 4600...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
