tilt deck trailer
/ tilt deck trailer #21
/ tilt deck trailer #22
Buy non-ethanol racing fuel. Expensive, but no ethanol. How much would you need? Maybe 1 gallon per year? Might cost $25 bucks.
Don't know about elsewhere but in greater New England look up "Pure Gas.Org" for non ethanol gas sources. I get it at the pump in S. Maine for $4
/ tilt deck trailer #23
How often do these trailer hydraulic systems fail other than a dead battery?
I've never had any failures on dump trailers or hydraulic dovetails and jacks over the years, except...
Two out of four hoses on my current Diamond C sprung leaks, one at a time. That made the dovetail and jacks inoperable. Luckily both failed at home.
Must've been a bad batch. Now I carry two spare hoses.
/ tilt deck trailer #24
Much ado about nothing.
/ tilt deck trailer #25
I had the lower pin on one of the 2 lift cylinders on my tilting deck disappear on a dirt road. Trailer did a nice pole vault, cylinder bent, hoses snapped. I tied things up & got to the camp site a mile away. I was able to unload the side by side by gravity by backing up slowly. Loading required 1 or 2 guys standing on the back to tilt it down to re-load the side by side. If I recall I was able to get the rear tires on before it started to un-tilt. It wasn't fun, but wasn't the end of the world.
Several dead batteries, resolved by jumper cables and/or replacing the battery.
The blown hoses from the pole vault was probably actually a better scenario than a dead pump as the cylinders could move freely. A dead pump would lock the cylinders in place. Pretty messy & bad from the environment but you could crack lines & use the loader to tilt the deck. Then the weight of the machine on the front of the deck to un-tilt it.
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
John Deere Planter (A62613)
John Deere Planter...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2025 Kearney 7'x14' Trailer (A64127)
2025 Kearney...
