tilt deck trailer
/ tilt deck trailer #1
johndeerefarmer
Texas
Deere 6105R, Deere 620, Deere 340G, Deere 329D
I have a Load Trail 32' tilt deck trailer. Wondering what you guys do if the pump fails and you can't raise it up to unload? IF it fails in the up position I can either use the gravity down feature on the wired remote or disconnect a hydraulic line. More worried about going somewhere and I can't raise it up? Thinking about buying a cheap Vevor double acting hyd pump and some extra hose and carry it with me. Thoughts?
/ tilt deck trailer #2
If you tee’d quick coupler(s) it would make it easy to use the manual pump.
How often do these trailer hydraulic systems fail other than a dead battery?
/ tilt deck trailer #3
Depends on the load and hydraulic circuit design on whether you need power tilt or not. If load is on wheels and heavy enough it should gravity dump once load is moved overcenter if circuit allows this. Not sure if there is a valve to prevent trailer from tilting due to load induced forces.
/ tilt deck trailer
Not worried about going down. Worried about going up. As I said I can use the gravity down button on wired remote or I could disconnect a hose.
/ tilt deck trailer
I don't know how often they fail but I prefer to be ready in case I am hundreds of miles away from home. Some of these hydraulic units have a manual pump, this one a KTI hydraulics units doesn't so that's why I am thinking about getting a cheap unit for backup
/ tilt deck trailer #7
I was talking about using the load on the trailer to dump if moved to position that is rear of tilt hinge so weight (gravity) dump the trailer.
/ tilt deck trailer
I would have to do that anyway to use the manual down over ride. Basically back it to the far rear until it started coming down.
/ tilt deck trailer
I think you are worrying about something that may never happen.
Already had trouble. Nephew borrowed the trailer. Went to lift up the deck and it wouldn't go. Battery was good. Wired or wireless remote didn't work. Jumped the solenoid and the pump ran. Finally disconnected the remote receiver and plugged the wired remote directly in. Was able to operate the unit. Then when he plugged the remote receiver back in, it worked too. So I guess the remote receiver locked everything up. Stupid design that the wired remote goes through the receiver.
Anyway this is why I got to wondering about some kind of backup
/ tilt deck trailer #12
Honda motor with a small 2 stage log splitter pump and tank.
Be done with the 12v bs stuff and the constant worry "is it going to work".
/ tilt deck trailer #14
Some pickups have PTO ports on the transmission or transfer case.
Mount a PTO and hydraulic pump and quick couplers near the rear bumper and you’ll be set.
However, it may cost a bunch and if you forget to turn the PTO off it may damage the PTO and the truck’s transmission/transfer case.
/ tilt deck trailer #15
Then the motor wouldn't start from sitting with the ethanol gas in it
Buy non-ethanol racing fuel. Expensive, but no ethanol. How much would you need? Maybe 1 gallon per year? Might cost $25 bucks.
/ tilt deck trailer #16
I just don't have these ethanol problems, period! Never had.
I treat my gas (5g cans) with "Stable-marine".
As you might be able to tell, I've had lots of problems with 12v electric over hydraulic be it batteries, or just plain weak and I'll never consider one again for anything but maybe a lift gate.😉
/ tilt deck trailer #17
non ethonal fuel here is about $5 per gallon
/ tilt deck trailer #19
I have adapted one of the Vevors, to actuate a thumb for my backhoe.
It is pretty slow, but does work just fine. 36" thumb.
$220
Now discontinued but they have others
Probably need the extra oil volume like this one:
Hard to find a less expensive option
/ tilt deck trailer #20
You have in my opinion limited options depending on what your load is.
-if load is on wheels, you may be able to roll it off with with a big drop if you have a high enough clearance on the load, or you can get ramps as a back up, but if a low load (mower with deck on) the angle on the ramp may be an issue.
-you may be able to disconnect the lines (be prepared to catch the oil) and then use gravity to force the tilt by moving the weight to the rear.
-have a backup pump system
-make necessary repairs to fix the failure.
