Tiller Tiller size?
/ Tiller size? #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I want some opinions!
My first tractor was a JD 755- 20hp-15pto. it pulled a landpride 15-50" just fine, plowed ground it was all she wanted. The next tracor was a 855- 24hp-19pto, it did not no there was a tiller back there (same tiller).
My NEW 4300 has 32.5 hp- 25.5pto. I'm tradeing my 50" in for a 25 series 62" or a 70" tiller. since the hp has increased 12.5hp I think it will pull a 70" tiller, this will over hang the tires 5" on each side (I wood really like that) compared to the 62" whitch will over hang 1" per side. I think the tractor would pull the bigger tiller with no problem. Comments
DDT
/ Tiller size? #2
DDT,
Since your 4300 has a 68inch wheel base I would figure you would want your tiller an inch or two wider than the tires.
The specs show that the 4300 can handle a JD 550&650 comfortable.
May dimes worth.
P.S.
Maybe Bird,DFB etc could shed a little more light on this subject.
Thomas..NH /w3tcompact/icons/wink.gif
/ Tiller size? #3
Dana, I think it'll depend to some extent on the ground you're trying to till; how hard, how deep you're going, moisture content, etc. I really think your tractor will handle the 70" just fine. My cousin uses a 62" behind his TC29D, which is certainly less power than you have and it runs quite easily.
Bird
/ Tiller size? #4
DDT
My 1720 Ford has 24 PTO HP and I pull a 60" KMC tiller just fine.
/ Tiller size? #5
I need a clarification from you'all. I have a TC35 w/ R-4's that measures over 72" wide at the backend. When I talked to my dealer and several others about tiller options, they all said that the width of the tiller wasn't critical in regards to the tractor width because I could use even a 48" tiller and "offset" it to one side thus basically tilling just on the left (or right) side of the tractor each pass. This obviously leaves a section on the "other" side untilled which means that I need to make half again as many passes. The advantage of this method, provided the tiller indeed "offsets" past the wheels, is that one can save a few $$ on a tiller, doesn't have to always be tilling a full 72" swath (for narrow bed uses), and it would relieve any doubts as to whether one's tractor has enough umph to handle a larger tiller. It all started out with a neighbor offering me his 50" tiller to borrow and my commenting that it was too small for my rig. Does this thinking make sense?
/ Tiller size? #6
Remember a couple of things:
Don't go larger than the manufacturer recommends for your tractor. If you do decide to go with a narrower tiller than your tractor, check to make sure the tiller will offset enough to cover at least one track. Personally, I'd sure be trying to get wide enough to cover your tracks. Not all tillers are equal, some do better with less HP even though they are the same width. You can also take a smaller bite if need be, not putting it so deep on the first path. Also factor in the kind of ground you have...hard packed clay needs more oomph than sandy soil...
/ Tiller size? #7
VTSTEVE, some tillers can be offset and some cannot, so if you go that route be sure you're buying one that can be offset. I would prefer a tiller just wide enough to cover both rear tracks. How often are you going to want to till a narrow bed, and be able to do it with a wider tractor, even if the tiller IS narrower? My rear tread is 54" and I'm using an RTS40 Bush Hog (40") tiller, offset to cover the track on the right side. That works just fine, but you do have to plan your route, and maybe drive a little extra distance, to till the whole garden without leaving any tracks showing. Of course, when I bought the tiller, I had a tractor that was only 40" wide. Now I wish I had a wider tiller, but this one works great, so I'm not going to spend the money for a wider one.
Bird
/ Tiller size? #8
VTSteve...
My KMC tiller can be offset too, but since it's 60' wide to start with, and I was told the smaller KMC tillers were aimed at landscapers, I always thought the reason for the offset was to get up close to retaining walls, house walls, trees etc....
/ Tiller size? #9
Thanks for all the great advice. How do I know whether a tiller can be offset or not. I assume that a new one's specs would mention the ability? What about on a used one - how can I tell? ALSO what is a good price on new or used tiller of varying brands. Am I correct in assuming that a tiller gets pretty hard use no matter what and how does that translate when one looks at a "less expensive" name (KingKutter or Caroni) vs. a more expensive one (Kuhn or ??) ? Thanks again.
/ Tiller size? #10
The KMC tiller says in it's ad that it can be offset. Scroll down to the sizes for smaller tractors.
As far as quality goes..... remember you get what you pay for... how well I know.
/ Tiller size? #11
DDT,
I have a JD 4300 and a Landpride 2555 tiller. The tiller will offset enough to cover tire tracks. My garden area hadn't been tended for over 25 years, and the 2555 done an excellent job. IMHO, I think the 4300 would have no problems handling the 2570 model. I know a guy that uses a 2562 on a JD 4200 without any difficulty.
Thx
Rick
/ Tiller size?
Rick and the rest of you, I'm glad that know one though I was nuts. If a 4200 pulls a 2562 then mine will have no problem with a 2570. My dauther got the calcultor out and figured 20 hp with a 50" swath and a 32hp with a 70" swath. She said the 4300 should have 6% more power than the 755 had useing a 50 tiller, So I guess were not all wet. Thanks for all the opions!!!
DDT
/ Tiller size? #13
DDT: I have a 84" Sovema tiller that probably weighs 800-900 lbs. and my 3710 has no problem tilling the max. of 6 inches.
DaveH
/ Tiller size? #14
VTSTEVE,
Either you streched your tape measure out a little or you've got some modifications to your TC35. Mine measures just over 68" in the back with R4s, and my 72" bucket is wider than the tractor.
I know this because of my 6' wide trailer /w3tcompact/icons/wink.gif
gary
/ Tiller size? #15
Oh Yea! I forgot to mention that the tractor has ice chains on it that effectively widen the rig another 1 1/2 to 2" on each side. I certainly hope that I won't be tilling with chains on but the way this winter is with snow - who knows?! Maybe we can find some variety of early tomato that thrives in the white stuff! I'll measure the tyres and let you know what they are rubber to rubber. On a related note, talked to an equipment dealer yesterday and he recomended against a 6' tiller as being too big for my rig. So I guess it's a narrower tiller that I can offset.
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
Log Chain (A65640)
Log Chain (A65640)
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
