throttle stop
/ throttle stop #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
There is a throttle stop that hits against my injector pump when I push the throttle all the way open. Is there a corect setting for this (it is adjustible)? Is it ok to adjust it so that the throttle opens farther to give more fuel to the motor?
/ throttle stop #2
The throttle on my 2210d is set to stop at 2600 rpms. I can't imagine have to run more rpms than that. I have found that 2100 to 2300 rpms is plenty for just about everything I have used it for. 2600 rpms seems to wind the motor pretty tight.
/ throttle stop #3
Kenmac,
Originally, there was a small safety wire twisted from the jam nut and to the threaded rod. This safety wire indicated where the factory set and adjusted fuel pump amount and timing.
Often, I have adjusted the throttle rod and related hardware. I am not positive but I think that you can damage the pump by setting (adjusting) the throttle and it's timing. Maybe someone else is a little better qualified to set us straight.
Mark
/ throttle stop #4
I can't imagine any reason to run a Yanmar over 2600 rpm.
Big Star Sign (A64127)
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
18.4-42 Tires (A65640)
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
