throttle stop
/ throttle stop #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
There is a throttle stop that hits against my injector pump when I push the throttle all the way open. Is there a corect setting for this (it is adjustible)? Is it ok to adjust it so that the throttle opens farther to give more fuel to the motor?
/ throttle stop #2
The throttle on my 2210d is set to stop at 2600 rpms. I can't imagine have to run more rpms than that. I have found that 2100 to 2300 rpms is plenty for just about everything I have used it for. 2600 rpms seems to wind the motor pretty tight.
/ throttle stop #3
Kenmac,
Originally, there was a small safety wire twisted from the jam nut and to the threaded rod. This safety wire indicated where the factory set and adjusted fuel pump amount and timing.
Often, I have adjusted the throttle rod and related hardware. I am not positive but I think that you can damage the pump by setting (adjusting) the throttle and it's timing. Maybe someone else is a little better qualified to set us straight.
Mark
/ throttle stop #4
I can't imagine any reason to run a Yanmar over 2600 rpm.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2007 MACK CTP713N TRI/A DUMP TRUCK (A59914)
2007 MACK CTP713N...
2008 Volvo VNL Sleeper Truck, VIN # 4V4NC9EJ98N489293 (A65563)
2008 Volvo VNL...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
