throttle stop
/ throttle stop #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
There is a throttle stop that hits against my injector pump when I push the throttle all the way open. Is there a corect setting for this (it is adjustible)? Is it ok to adjust it so that the throttle opens farther to give more fuel to the motor?
/ throttle stop #2
The throttle on my 2210d is set to stop at 2600 rpms. I can't imagine have to run more rpms than that. I have found that 2100 to 2300 rpms is plenty for just about everything I have used it for. 2600 rpms seems to wind the motor pretty tight.
/ throttle stop #3
Kenmac,
Originally, there was a small safety wire twisted from the jam nut and to the threaded rod. This safety wire indicated where the factory set and adjusted fuel pump amount and timing.
Often, I have adjusted the throttle rod and related hardware. I am not positive but I think that you can damage the pump by setting (adjusting) the throttle and it's timing. Maybe someone else is a little better qualified to set us straight.
Mark
/ throttle stop #4
I can't imagine any reason to run a Yanmar over 2600 rpm.
2017 P.J. Deck Over Trailer, VIN # 4P5F82021H1265098 (A65563)
2017 P.J. Deck...
Arrow Board (A62613)
generator trailer (A61569)
generator trailer...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
ATTENTION! PLEASE READ (A64127)
ATTENTION! PLEASE...
2018 Kubota U35-4 (A64126)
2018 Kubota U35-4...
