Three point valve broken!!!
/ Three point valve broken!!! #121
I know California痴 YM240 has the diverter valve, those of you with the loader plumbing run the same way Hoye tells you to, without a diverter valve, does your system do this when working the loader?
It's been a while, but I did have some issue with mine, I just can't remember what that issue was.
I plumbed my 3 point using power beyond not long after having the loader put on.
I'm glad to see you got it working thought. I had no other clues.
From sitting from behind a computer screen, It's hard to know that someone else had butchered up the linkage
/ Three point valve broken!!! #122
Agreed, I am not sure why I didn’t realize there is supposed to be a snap ring on the other side, until I had heverything off and apart. I guess it’s a little hard to tell in there honestly.
You say you plumbed it with power beyond, I can do that, but where/how did you route the standard outlet from the loader?
/ Three point valve broken!!! #123
HP line from the pump is cut and routed to the loader valve. PB out of the loader valve goes to the hp line for the 3 point.
You will then have to find a place for a HYD return for fluid to the sump from the loader valve. possibly add a T in your return line to the pump
I believe hoye now sells a device you can add to the HYD fill to add a return line.
I don't know how big of a guy you are and, That may get in the way of getting on and off the tractor.
They do sell something that thread into the hydraulic resivoir and has a banjo return fitting and then the dipstick threads into the top of that all. I have either seen pics of it or on their site?
/ Three point valve broken!!! #126
Good to know that now. Ugh, sometimes I really like Hoye, and other times they drive me nuts. If they would have put on their little “add a loader” kit/instructions that PBY is recommended to reduce pressure interference with the 3PT and mentioned they have that adapter to plumb it correctly, I for sure would have bought it.
I’m going to put an inline check valve in there for now. If that doesn’t work, I’ll order that fill hole adapter thing on Monday.
/ Three point valve broken!!! #127
I see in a prior post reference to a diverter valve on YM240. No.
There is a fitting identical in function to what Hoye sells. In both cases they only allow to loader to be plumbed in series ahead of the 3-point. There is no 'valve', no proportioning or back-pressure control, in these diverter blocks.
My second YM186D does have a separate diverter valve that guarantees minimum pressure to its power steering in addition to its simple diverter block that provides plumbing to its loader, so there is a difference.
Lots of photos, diagrams, advice in this old thread:
https://www.tractorbynet.com/forums/yanmar/221299-loader-plumbing.html (The first YM186D referenced there didn't have a loader, only a loopback hose between the diverter block out/in ports).
/ Three point valve broken!!! #128
I was actually reading that thread last night and this morning!
/ Three point valve broken!!! #129
Actually, I was talking to Dave @ Daves tractors on the phone one day (long ago) and he told me he use to be a yanmar dealer and that, yanmar actually had such a fitting back in the day. for fluid return to the sump.
I don't believe anything like that part hoye sells now, was produced at that time
I was searching my work computer for a file and came across this that i forgot i even had. This may have helped you out Indirocz, had i found it sooner!!
  • YM240Hydraulic.pdf
/ Three point valve broken!!! #131
Great find digging, haha! One of you posted the same thing a few pages back, and so I have it printed out.
Maybe Ken posted it. I don’t remember anymore, but thank you to everyone for your time and help.
I ordered that dipstick fill adapter from HOYE, it finally came in yesterday.
Just a bit ago I picked up the rest of the hydro fittings I need to use PBY and a hose to run over to the fill port for the loader out return.
HAHA, I didn't notice that! i know California posted a Yanmar Hydraulic poster/flyer but didn't realize the book was posted...oh well, its here 2x for future references. haha.
/ Three point valve broken!!! #133
Just an update, finally was able to get the power beyond hooked up and that stupid fill adapter put in that Hoye never mentions with their “add a loader” kit.
Everything is working fine now.
Thank you everyone so much for your help, it is greatly appreciated.
That's good to hear!!
Did you get your original setup working or did your get used parts from Hoye to put it back together?
/ Three point valve broken!!! #135
good to hear you got it working. I think most loaders are just routed through the inlet loader valve and power the 3pt on the outlet of the valve.
I believe here was a guy that use to post in the HYD. section that gave me the idea of using pb to power the 3 pt and all has worked well since. Well, until the 3pt decided to fall from time to time. But with the issues you guys are having with that control valve, I think I'll just deal with the 3 pt issue
/ Three point valve broken!!! #136
Still using original parts.
It’s not perfect but works well enough now.
Aaron said he doesn’t have the linkage I need.
/ Three point valve broken!!! #137
I realize a lot of older ones may be plumbed that way. However the problem I was having of back pressure pushing back into the loader control valve when the 3pt was up has now been solved by allowing the PBY to power it. There is still some drop in the box blade when operating the loader, but not nearly as much as before using PBY, and no leakage back through the loader valve.
I wish Hoye would have said “it is recommended” to do it that way in the first place, and didn’t “hide” that fill adapter in the dark corner of their website. Haha.
Oh well, all is working now.
This little tractor has got a lot of work to do to make up for itself.
/ Three point valve broken!!! #138
I believe Fredricks still plumbs their tractor loaders this way. They installed my loader a few yrs ago and plumbed it that way. I changed it, about the same time I added the valve for the grapple / thumb I added
Hoye must have had those filler adapters made. I don't think they had them when I made my return port.
I had what appeared to be an inspection plate just behind my shifter. I used this plate and welded a short threaded nipple and piped it up instead of using a hyd hose.
/ Three point valve broken!!! #139
The YM240 owner's manual shows that way, the simple series method and not PBY, as how to add a loader. There's lots of advice online saying this is wrong and will put excessive backpressure on the loader valve, eventually damaging it. Could be. My loader valve (third-party, not Yanmar) original from 1980 was dribbly when lifting maximum weight so I replaced it.
I saw a post somewhere saying a Kubota dealer stopped using the series method when they identified that as the cause for warranty repairs a few years after installation.
Apparently series plumbing is generally 'good enough' for casual use while PBY is preferable for a loader in continuous commercial use.
/ Three point valve broken!!! #140
In all fairness I believe a solid 95% or more of the Yanmars are plumbed the way we describe in our instructions. This is the first time I have heard of it causing a problem in almost 20 years. I suspect your loader valve was leaking due to the original TPH linkage problem which caused long term back-pressure (you said the only way your three point would stay up was by leaving the TPH valve in the lifting/relief position). That is just my theory but your situation is pretty unique and I don't think the loader plumbing was to blame.
Yes, we had those made by a local machine shop a few years ago.
