rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,945
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
In all fairness I believe a solid 95% or more of the Yanmars are plumbed the way we describe in our instructions. This is the first time I have heard of it causing a problem in almost 20 years. I suspect your loader valve was leaking due to the original TPH linkage problem which caused long term back-pressure (you said the only way your three point would stay up was by leaving the TPH valve in the lifting/relief position). That is just my theory but your situation is pretty unique and I don't think the loader plumbing was to blame.
Yes, we had those made by a local machine shop a few years ago.
It must have been about 1980 when my local Yanmar dealer decided he had enough of trying to get loaders to work properly in series with the tractor's own 3pt hydraulics with nothing more than the tractor's own hydraulics and a passive valveless diverter block. So he switched to doing it the correct way. He mounted all his loaders to be driven by a small outboard hydraulic pump coupled to the outer face if the crankshaft pulley. That way the loader hydraulics run separately from the tractor's internal 3pt hydraulics. I'm not sure if he came up with the idea or whether Yanmar did, but done that way the loader is fast, powerful, and doesn't have any cross-feed or valve problems.
I was at his shop one day and remember him throwing away a box full of those old valveless diverter blocks. I did keep one around for years just to remind myself that there is always a better way to do something....
For anyone having loader hydraulic problems like I see in this thread, a separate pump is the way to go. A lot of tractor guys stopped using that old "loader in series with the 3pt hydraulics" lashup shortly after it was introduced as a way to put cheap hydraulic loaders on the old Fords & Massey & IH tractors of the 1950s. For those tractors it was "cheap & better than nothing", and besides...without 4wd those old tractors couldn't do any more than lift and carry with their old pipe loaders anyway.
Yes, a diverter block can work, and so can a manual hydraulic valve. But an independent system does much better.
rScotty
