Three point valve broken!!!
/ Three point valve broken!!! #61
I keep thinking that it has to be the feedback linkage that is causing the problem. Your handle does not work like it should. I can take a picture of my YM2001 linkage this afternoon but it might not be exactly the same.
I don't understand the problem but it seems to me if both the new loader valve and the new 3-point control are blowing out seals then there's an overpressure problem somewhere. Maybe a sump return that is sealed in some control positions, when it shouldn't be?
The 3 pt seal moving is probably just a bad tolerance when it was machined. He said the seal is loose in it, and as the button is presses just the friction pushes the seal out.
I believe poor machine work, after all my muting bolt pattern on my first one didn't match up with the holes and I could only put 3 out of 4 bolts in the valve due to misalignment.
California,are you at the farm to take a pic of your tractor or do you have one on your PC?
Carey do you have your linkage pictures or can you take a pic to post here?
/ Three point valve broken!!! #64
California, are you at the farm to take a pic of your tractor or do you have one on your PC?
Sorry, wife says we are stuck in town until after Halloween. Actually its kinda fun. Along with candy I hand out apples, including undersize ones to the little kids. Sometimes after a bite they say they've never had an apple with good flavor before. I look for a nod from parents for the little kids, so far all approve.
We get neighbor kids, carloads of kids and teens from poorer neighborhoods, then waves of kids trick or treating after the nearby Junior High Halloween party lets out. It seems like a good idea to be home when all this cheerful chaos is going on.
I expect to get back over to the ranch (orchard) by the weekend. It's 100 miles each way so I can't just pop over there for a photo, sorry.
Here's an old thread where I and others posted photos of the YM2000 3-point lever. It might be helpful.
https://www.tractorbynet.com/forums/yanmar/353947-3pt-hitch-lever-adjustment.html
Here's some more pix I've posted here before:
https://www.tractorbynet.com/forums...2-ym1700-draft-control-587946-feedbackrod-jpg
in thread
https://www.tractorbynet.com/forums/yanmar/51711-ym1700-draft-control.html
https://www.tractorbynet.com/forums...9-all-us-yanmar-owners-ym3ptloweringvalve-gif
thread
https://www.tractorbynet.com/forums/yanmar/86500-all-us-yanmar-owners.html
https://www.tractorbynet.com/forums...6482-unknown-part-p1090564r3ptfeedbackrod-jpg
thread
https://www.tractorbynet.com/forums/yanmar/99395-unknown-part.html
(for some reason that thread is missing its photos. There was a short time while TBN renamed their photo folders or something, causing this).
Several pix in this thread
https://www.tractorbynet.com/forums/yanmar/221299-loader-plumbing.html
and some good advice on loader plumbing
Factory hydraulic posters
https://www.tractorbynet.com/forums/yanmar/220599-hydraulic-system-diagrams.html
Forum General Forums Hydraulics
how much loader drop is acceptable?
https://www.tractorbynet.com/forums/hydraulics/229020-how-much-loader-drop-acceptable.html
Thread where I asked a lot of questions about loader plumbing
https://www.tractorbynet.com/forums/yanmar/269934-power-beyond-vs-series-loader.html
Just for fun, off-topic, found this while digging through photos I've posted here :D
554278d1526328223-whats-img-code-off-helphelpimbeingenlightened2-jpg
/ Three point valve broken!!! #65
I looked at mine and it is totally different. It is all on the side and not on the top.
California's post has all the pictures.
/ Three point valve broken!!! #66
Had time to fiddle with it a bit tonight. I致e determined that I need to have an adapter and gauge put together so I can monitor pressure from the pump. I believe that is the next step.
I bypassed the loader controls completely and ran a jumper hose in its place so it is again routed as stock.
I tested with my original valve, and the Hoye valve (making sure the seal stayed pushed in).
I have determined that due to the internal throw of the spool inside the 3point valve that the position of the handle doesn稚 matter I don稚 think.
I also want to add that mine has been re-welded where the vertical push bar is that attaches to the handle shaft and pushes on the spool pin. But after watching its movement, and looking at the throw of the spool, along with adjusting the travel linkages, I don稚 think that is my problem either.
While I obviously DO have some hydraulic pressure, if I open the speed lever more than 1/4 turn with the Hoye valve, the 3 point will not pick up with the box blade attached at even 1500rpm.
It may move a little but it just seems to bypass pressure at that point.
When the 3point and box blade is up, no matter where I adjust the linkage, again, there is always pressure being bypassed in either control valve, you can (in person) always hear that “loaded” sound. There are different frequencies of this sound, but it never goes away, until the 3pt begins to drop.
I will get a gauge configured and hooked up, and that should tell us if I have correct pressure out of the pump.
One of the things I am wondering is, if it is possible that there is not enough hydraulic pressure produced to push back on the spool pin against the control lever creating this 渡eutral position, and that the weight of the 3 point along with the external spring tension is overpowering the spool valve in the 3pt control valve?
/ Three point valve broken!!! #67
Ours are on the side.
/ Three point valve broken!!! #68
California, one of those links was pretty insightful, thank you!
It helped to clue me in as to why when the 3pt is up, I am getting that fluid feedback back through the loader valve control spool.
Which indicates to the problem I am having which is not being able to find the “neutral” for the 3pt.
What if, I have it adjusted and get it into the neutral spot, but the 3pt doesn’t hold up? What would that mean?
/ Three point valve broken!!! #70
I still think that it is the interaction between 27, 34, 47 and 40 in this picture. It is really hard to tell in your video. It is almost as if 40 and 47 are not pinned together.
THREE_POINT_CONTROL: Yanmar Tractor Parts
Those two linkages should counteract the movement of 34 to find the neutral point of the valve.
/ Three point valve broken!!! #71
Which indicates to the problem I am having which is not being able to find the 渡eutral for the 3pt.
What if, I have it adjusted and get it into the neutral spot, but the 3pt doesn稚 hold up? What would that mean?
I've been watching this thread over the last day or so but I don't have any solutions.
Seems to me your theory of fluid leaking back through the loader control might be a clue of excessive pressure, a blocked return path, downstream from the loader valve. The fluid is supposed to just bypass at zero pressure through the loader valve and back to the sump (also bypassing through the 3-point control when it isn't in use) - except when a loader control is pushed/pulled to divert fluid out to a loader cylinder.
If all the hydraulics aren't the cause, then possibly that repaired linkage isn't right. The linkage may be calling continually for 'raise 3-point' when actually you don't want that.
I'm stumped. Aside from all my beginner questions in the threads I linked, i don't have much knowledge of hydraulics. I've never had to troubleshoot hydraulics like you are doing. My loader control replacement project ended up as a like-for-like replacement of the old dribbly control. After asking a lot of questions I decided to ignore some of the graybeard hydraulic specialists (self proclaimed?) on TBN who insisted the way Yanmar recommends in the YM240 manual, could never work. It worked before the replacement, and now, after.
/ Three point valve broken!!! #72
Not sure what this means. The valve on my YM2001 is on the side of the lift cylinder instead or on the top like the YM2000.
Ahhhh okay, I thought you were meaning the linkage.
/ Three point valve broken!!! #73
And what I知 saying is, when I get it close to any type of 渡eutral when adjusting the linkage thread by thread, the 3point still sinks to the ground and puts load on the pump. It痴 a little boggling..
California, could you post pictures of your linkage rods and how they sit with the lever all the way forward and the vertical finger not hitting the 3point spool pin by chance?
/ Three point valve broken!!! #74
In note to the “blocked path down stream from the loader valve”
With tractor off of course, I can put a funnel in the open hole where the banjo bolt screws into the 3pt valve and with the handle back, fill that funnel with fluid, push handle forward, and it will all go down and empty the funnel.
/ Three point valve broken!!! #75
I expect to get back over to the ranch (orchard) by the weekend. It's 100 miles each way so I can't just pop over there for a photo, sorry. I'll post a photo on the weekend.
/ Three point valve broken!!! #76
Ahhh okay, no worries! I forget not everyone who has a tractor has it at their house like we do in Texas. Haha
If Carey pops in to read this, I think he may have some linkage pics on his computer, but if not his ym2000 is right out back and he can take a pic for us. He is a regular on here.
I have been at my farm the last 2 weekends and meant to get some pics of the linkages for you this last weekend, but I was so busy putting my new valve on, bush hogging, trimming trees on field edges, or hunting I forgot to.
/ Three point valve broken!!! #78
I can take some and post them from my 3110 if that would help you. Just tell me what you need.
I have no idea if they are set up the same or not
/ Three point valve broken!!! #79
/ Three point valve broken!!! #80
Cherry Picker (A65640)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
265/75R16 New Tire (A62613)
265/75R16 New Tire...
Stand-On Mower (A64553)
Stand-On Mower...
4004SFL (A59228)
4004SFL (A59228)
