three point fork lift mast?
/ three point fork lift mast? #1
BHD
easten Colorado
JD 4020
yes I have forks for my loader,
but one can not see,
hard on the front axels, (at times impossible), (have considered a review type camera on the loader to see the forks).
has any one build a 3 point unit for the rear of the tractor to work like a real fork lift?
if so have pictures and how do you like it,
/ three point fork lift mast? #3
The guy I bought my tractor from was a roofer and had the mast from a forklift mounted on the rear. It was homemade but worked for him. Sorry no pics didn't need it so didn't buy it
/ three point fork lift mast? #4
There was a guy around here that was doing something like that on small case lawn tractors. It was designed to pick up trees at nurseries. I think he sold about a 20 of them.
/ three point fork lift mast? #5
I see forklift masts with 3pt pins on it and a Sa hose now and then..
/ three point fork lift mast? #6
Didn't build it, bought it at an auction 10 or 11 years ago. Sold it 4 years ago when I sold the tractor.
Got to have a hydraulic top link.
/ three point fork lift mast? #8
Just saw one auctioned off, went for $325.
Max Lift Cap. 4,000 lbs. Max Lift Hgt. 70" Fork Size 1-1/2 x 4 x 46" Solid Fork Cap. 2,400 lbs. each Fork Spread Adjustable 20-48" 3-Point Hitch, Category II Lift Cylinder 2-1/2 x 42" Stroke Wgt. 675 lbs. Mod:40, S/N:747237.
Model:40
S/N:747237
Condition: GOOD
Probably should have bought it :(
/ three point fork lift mast? #9
How big is ur tractor. My old neighbor has arOund 100hp. With 2 really heavy duty fork lift mast he custom fab forto hook to a 3pt. He used them so load and stack hay. At least till he got a skid steer
/ three point fork lift mast? #10
Messed up once where I worked we had 3 or 4 old FL that were going to scrap, I DID get the forks and frame for them off one of them and other maintenance guy said take whole mast & make 3pt with it. I said just wanted frame & forks for FEL use... :/ Ya never said I was all that smart lol
The rest of the mast & truck was dropped into dumpster for scrap steel.
mark
/ three point fork lift mast? #11
One thing to be mindful of with those fork lift type 3pt mast set ups:
Check garage opening heights vs mast height when entering or leaving - same goes for low tree limbs.
I mention this after having witnessed someone in a hurry to load a truck, zipping out of the warehouse, lowering a pallet of cedar shakes grabbed from up on a storage rack, but not lowering them quite in fast enough. What a mess.
thanks for the ideas, and links
/ three point fork lift mast? #13
can someone enlighten me why some have chains+cylinder and some just a cylinder ? What are the pro's <-> cons of both systems ? Safer, stronger, ... ??
/ three point fork lift mast? #14
Chains allow for a shorter cylinder (moving the cylinder 1" moves the forks 2") which allows for multistage masts and cheaper cylinders (cheaper to use a thicker cylinder than to use a longer one).
Most forklifts have chains, not a direct connection to the cylinder.
Aaron Z
/ three point fork lift mast? #15
Same reason (or opposite I suppose) you have multiple loops of chain/cable on a crane or chain pulley. It basically acts like a gear. Increased movement and speed at the cost of power or decreased movement & speed with more power.
Also not unlike your average extension ladder. It makes it easy to raise a boom really high above the mechanism raising it.
/ three point fork lift mast? #16
How badly was the mast damaged
/ three point fork lift mast? #17
/ three point fork lift mast? #19
Ok I get it now, thanks for explaining why they use chains guys.
/ three point fork lift mast? #20
Yikes!
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
(10) UNUSED 2.5" RATCHET STRAPS (A60430)
(10) UNUSED 2.5"...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
80" BOX BLADE (A60430)
