three point fork lift mast?
/ three point fork lift mast? #1
BHD
easten Colorado
JD 4020
yes I have forks for my loader,
but one can not see,
hard on the front axels, (at times impossible), (have considered a review type camera on the loader to see the forks).
has any one build a 3 point unit for the rear of the tractor to work like a real fork lift?
if so have pictures and how do you like it,
/ three point fork lift mast? #3
The guy I bought my tractor from was a roofer and had the mast from a forklift mounted on the rear. It was homemade but worked for him. Sorry no pics didn't need it so didn't buy it
/ three point fork lift mast? #4
There was a guy around here that was doing something like that on small case lawn tractors. It was designed to pick up trees at nurseries. I think he sold about a 20 of them.
/ three point fork lift mast? #5
I see forklift masts with 3pt pins on it and a Sa hose now and then..
/ three point fork lift mast? #6
Didn't build it, bought it at an auction 10 or 11 years ago. Sold it 4 years ago when I sold the tractor.
Got to have a hydraulic top link.
/ three point fork lift mast? #8
Just saw one auctioned off, went for $325.
Max Lift Cap. 4,000 lbs. Max Lift Hgt. 70" Fork Size 1-1/2 x 4 x 46" Solid Fork Cap. 2,400 lbs. each Fork Spread Adjustable 20-48" 3-Point Hitch, Category II Lift Cylinder 2-1/2 x 42" Stroke Wgt. 675 lbs. Mod:40, S/N:747237.
Model:40
S/N:747237
Condition: GOOD
Probably should have bought it :(
/ three point fork lift mast? #9
How big is ur tractor. My old neighbor has arOund 100hp. With 2 really heavy duty fork lift mast he custom fab forto hook to a 3pt. He used them so load and stack hay. At least till he got a skid steer
/ three point fork lift mast? #10
Messed up once where I worked we had 3 or 4 old FL that were going to scrap, I DID get the forks and frame for them off one of them and other maintenance guy said take whole mast & make 3pt with it. I said just wanted frame & forks for FEL use... :/ Ya never said I was all that smart lol
The rest of the mast & truck was dropped into dumpster for scrap steel.
mark
/ three point fork lift mast? #11
One thing to be mindful of with those fork lift type 3pt mast set ups:
Check garage opening heights vs mast height when entering or leaving - same goes for low tree limbs.
I mention this after having witnessed someone in a hurry to load a truck, zipping out of the warehouse, lowering a pallet of cedar shakes grabbed from up on a storage rack, but not lowering them quite in fast enough. What a mess.
thanks for the ideas, and links
/ three point fork lift mast? #13
can someone enlighten me why some have chains+cylinder and some just a cylinder ? What are the pro's <-> cons of both systems ? Safer, stronger, ... ??
/ three point fork lift mast? #14
Chains allow for a shorter cylinder (moving the cylinder 1" moves the forks 2") which allows for multistage masts and cheaper cylinders (cheaper to use a thicker cylinder than to use a longer one).
Most forklifts have chains, not a direct connection to the cylinder.
Aaron Z
/ three point fork lift mast? #15
Same reason (or opposite I suppose) you have multiple loops of chain/cable on a crane or chain pulley. It basically acts like a gear. Increased movement and speed at the cost of power or decreased movement & speed with more power.
Also not unlike your average extension ladder. It makes it easy to raise a boom really high above the mechanism raising it.
/ three point fork lift mast? #16
How badly was the mast damaged
/ three point fork lift mast? #17
/ three point fork lift mast? #19
Ok I get it now, thanks for explaining why they use chains guys.
/ three point fork lift mast? #20
Yikes!
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 Peterbilt 387 with Wet Kit (A61306)
2005 Peterbilt 387...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61306)
PENDING SELLER...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Flatbed Truck (A55973)
