Think tank advice
   / Think tank advice #11
You would also only have to have a winch on one side that way.
   / Think tank advice #12
bones1 said:
Thanks for the quick replies.
Egon, I'm trying to picture just what you mean.
Lugnut, thought about springs but when the ramps are on the ground is where I have trouble lifting the dead weight.I can lift them, ONCE.
Snowridge, what if just one winch was mounted underneath the trailer say midway back or closer to the ramps and connected to a tab or leg welded to the cross pipe that the ramps ride over.Of course then the ramps and pipe would have to be drilled to allow for adjustability,in or out and to allow both ramps to raise and lower in unison.
That would mean a short arm, which would require a very stout pull, probably in the thousands of pounds. It would require a very powerful winch. It would probably make more sense to drive the arm with some sort of linear actuator or hydraulic ram. 12 volt hydraulic pumps are available.
   / Think tank advice #13
I solved this problem by putting an electric jack post on the trailer tongue. The trailer kneels, so you can just drive up on the beaver-tail. So what if the tow vehicle raises up a bit. This way you can load even without the truck attached (need 12v, though).
   / Think tank advice
I would prefer to have the winches and or rams below the trailer and out of the way.Snowridge, I think one of these might be adapted to work from below, somehow.Linear Actuators
dbdartman,thanks for the idea.
zzbyv6, never thought of that.
   / Think tank advice #15
I don't think the 400 lb max force would cut it. Assuming you are going to have a rotating tube move both ramps at one, you are looking at some serious forces. The crank arm would be severely limited by available space, which means a short moment arm, and again, I think you are looking at 1,000s of lbs. I'm not familiar enough with linear actuators to know if they are available in an appropriate size at an affordable price.
I tend to think hydraulic would be the best bet for the forces involved.
   / Think tank advice #16
Why not contact a lift gate manufacturer or handicap lift manufacturer to see if there is something available in kit form? Or a splined shaft for the ramps, so they are still adjustable side to side and a 12v servo (winch) motor?
   / Think tank advice
[quote Or a splined shaft for the ramps, so they are still adjustable side to side and a 12v servo (winch) motor?[/quote]
Pete, that would be ideal but splined components would be pricey.Attaching a motor to spin the pipe and ramps together as a unit would be perfect if I find the correct motor.Would have to be somewhat small, strong, low rpm, and reversible.Wouldn't know how to size a motor for this application other than a good guess.Or just take the cable off a small reversible winch and attach it direct.
Got me thinking some more.:confused:
   / Think tank advice #18
How about just trade for a tilt trailer.
   / Think tank advice #19
The square tubing would be relative cheap. You would need 2 sizes, one that would fit snuggly inside the other. You would also need 2 different sizes of round tubing to make the ends that will attach to the trailer.
A small atv winch with the cable hooked to a pulley mounted on the outside of the round tube should easily pull both ramps up. You may have to try a couple of different sized pullies to find one with enough leverage and speed to work properly. A spring or two to might be necessary to assist in the lifting.
I can picture what I have described, but I am not sure if I have explained it so that anyone else can.:confused:
   / Think tank advice
lugnut, I need a visual.:confused: I can see where the two pieces of square tubing would take the place of a spline but I can't see what the 2 pieces of round are for.Do you have time to draw it in Paint and post it?.
2013 Ford F-450 Flatbed Service Truck (A55973)
2013 Ford F-450...
flooring (A55758)
flooring (A55758)
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
17101 (A55851)
17101 (A55851)
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
