Think tank advice
   / Think tank advice #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Because of up coming back surgery I have a need now to motorize the heavy ramps on my trailer.Trying to come up with a design to raise and lower the ramps either with a small winch or linear motors.The ramps move freely on a pipe to go up and down.If you had to do it, what would be your idea?.Thanks for any input.The link below is my trailer.
http://www.downtoearthtrailers.com/images/downtoearthtrailers/64530001.jpg
   / Think tank advice #2
Place vertical posts outboard of each ramp and use one electric winch with cables?? Vertical post have to be far enough outboard to clear equipment being loaded.:confused: :confused:
Under hung sliding ramp that cane be pulled forward or back with cables. :D
   / Think tank advice #3
How about some springs like some of the larger trailer ramps?
   / Think tank advice #4
You could mount a small 12 volt winch on each fender. You obviously need to clear anything loaded onto the trailer, so having a central winch at the front is probably out.
You would need a removable gin pole for the ramps. If you are not familiar with the term, a gin pole is a temporary pole, usually mounted at right angles to the main object to be lifted. It allows the lifting cable to approach the top of the object at the correct angle for the start of the lift.
Once the object being lifted gets high enough, the gin pole is no longer required.
But if this is a long term condition, I think I would first see if I could find a trailer with powered ramps and forget the home brewed solutions. I would think somebody makes such a thing.
   / Think tank advice #5
I have that, and my ramp still takes some effort. I wouldn't want to do it with a bad back. I am assuming the OP will not be able to lift much of anything.
   / Think tank advice #6
Quick & dirty idea. Tube (thick red) welded to ramp at an angle connected to a winch on the fender (thin red). As long as the top of the tube (on the ramp) is higher than the pivot point (when the ramp is down) it'll raise the ramp. Store the ramp below vertical & drop.
   / Think tank advice
Thanks for the quick replies.
Egon, I'm trying to picture just what you mean.
Lugnut, thought about springs but when the ramps are on the ground is where I have trouble lifting the dead weight.I can lift them, ONCE.
Snowridge, what if just one winch was mounted underneath the trailer say midway back or closer to the ramps and connected to a tab or leg welded to the cross pipe that the ramps ride over.Of course then the ramps and pipe would have to be drilled to allow for adjustability,in or out and to allow both ramps to raise and lower in unison.
   / Think tank advice #8
looking at your angle I would think an old rim welded on each side of trailer, small winch mounted at trailer deck height. test angles with rope and rim before welding any thing on. Or check on those "Cranes" that you mount in truck bed to load. I know there has to be an easy way.
   / Think tank advice #9
This is the gin pole idea I mentioned, but the pole needs to be longer and at a right angle to the ramp. It also needs to be stabilzed, so that it won't cant left or right.
If nothing is ever to be loaded that would have any pieces or parts that extend beyond the outer edges of the ramps, it might be feasible to weld the gin poles directly onto the sides of the ramps.
   / Think tank advice #10
You could replace the round tubes on the trailer and ramps with square tubes. That way, you could lift the ramps with a winch and still be able to slide them in or out.
2023 JOHN DEERE 333G LOT IDENTIFIER 242 (A53084)
2023 JOHN DEERE...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
John Deere 6120E (A50323)
John Deere 6120E...
40' CONTAINER (A51248)
