Traction Things that go "clunk" in the night
   / Things that go "clunk" in the night #1
gpajimbo1180
Colorado Springs, Co
Kubota M7060
YM4220 suddenly started making a random clunking noise from the right rear. You can actually feel it and it sounds like dense metal clunking together. It is a little perplexing since it is not occurring in a regular pattern, it's more like clunk...... Clunk..................clunk...clunk.
Any similar experiences or thoughts? I'm thinking axle bearings but...???
Thanks in advance for the brain power.
   / Things that go "clunk" in the night #2
Check your lug nuts. And any bolts between wheel center and rim, if yours aren't welded together. If welded, there may be a broken weld.
And welcome to TBN.
Bruce
Thanks Bruce, that did it. it was the outer bolts that were the culprit. Not much just a 1/4 turn but it was enough.
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
SKID STEER MOUNTING PLATE (A60432)
SKID STEER...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
