BleedingOrange
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 2,957
- Tractor
- Kubota BX 2370
Great stuff. Can those 2 posts be accidental pushed over, or completely removed, to make turning a lot easier ?
No because there’s a chain pulled between them to keep the party punks and their lifted trucks out of the field.Great stuff. Can those 2 posts be accidental pushed over, or completely removed, to make turning a lot easier ?
I was thinking removing the one on the right would give 5-6 ft more room.Great stuff. Can those 2 posts be accidental pushed over, or completely removed, to make turning a lot easier ?
That would be nice. The owner is a great guy. has a backhoe and pulled me out once when my son got a little too close to some soft ground….I was thinking removing the one on the right would give 5-6 ft more room.![]()
Your point is well taken, but only in select areas of the country. Two wheel drive used tractors are available with high horsepower at (relatively) attractive prices.Do you need 4wheel drive for a dedicated mowing tractor?
My neighbor has two tractors. Both 100 hp. One is 4 wheel drive and he barely uses it. The other is a 2 wheel drive, cab, and no loader.
I was watching him mow with his 15 foot batwing yesterday, and I was impressed at how quickly he could turn around. I bet his visibility is really good too!!!! I talked to him later in the day and he said that it's night an day better mowing with the 2 wheel drive tractor. The more I thought about it, the more it makes sense if traction isn't needed.
Yeah, I'm "that guy" too, on this farm. To the point I have put my hand on the manual throttle and feet lightly on each brake, saying, "When this freight train breaks loose, what's my plan to land it at the bottom?"I seem to be “the guy” that does all the steep/dangerous ground in my area, so yes, definitely want 4WD and a cab.
I’m going out in comfort and safety!
For me the fact that the 2wd tractor has no loader would automatically make it better for mowing.Do you need 4wheel drive for a dedicated mowing tractor?
We have had a couple guys get banged up real good around here rolling over on hills.Yeah, I'm "that guy" too, on this farm. To the point I have put my hand on the manual throttle and feet lightly on each brake, saying, "When this freight train breaks loose, what's my plan to land it at the bottom?"
And I don't allow others to mow certain areas where I go. No bravado here...just lucky enough to learn how close you can get to the edge over decades. But younger people, a hard no, for their safety and my conscience.
But if the AC or heater ain't working, other folks are doin' it, not me at my age LOL.
Yeah, the object is to never let the tractor and load get sliding sideways with any speed. When the downhill tire hits the slightest obstruction, the machine will rotate over and start rolling with the result you describe. Quick differential braking and throttle jabbing can keep you at an angle that is a trade-off between straight down and slightly across the bank.We have had a couple guys get banged up real good around here rolling over on hills.
We call it getting “tumble dried” (like a person being tumble dried in a clothes drier) when you roll sideways on a hill.
Plus it's real handy to have backup for when something goes down for a couple of days.A little more mowing action on Friday. Steep roadside bank. Great supplemental income while waiting for hay to dry. I’ll do $40K in field mowing this year. My goal is to double that in the next 2 years and have a tractor dedicated to just mowing so the challenger I currently use is devoted solely to hay.
I’m really happy with the Challenger. Been a great tractor. Would like to buy another similar loader tractor to cut down on using it for so many tasks. I’d prefer to cut down on the hours it is used and spread the hours out over 2 loader tractors.
YepPlus it's real handy to have backup for when something goes down for a couple of days.
I have a 2810. Mine will pile up the grass behind the main cutter and be clean under the wing. I got it to mow ditches. Yesterday was the first field I mowed. My 8 foot one will spread the cuttings much better.Your point is well taken, but only in select areas of the country. Two wheel drive used tractors are available with high horsepower at (relatively) attractive prices.
The problem comes when trying to have good directional control and provide enough tractive power when dragging a heavy boat anchor behind us... And yes, I can use differential brakes to steer on hillsides - I'm old.
For perspective, my Bushhog 2815, tricked out, weighs about six thousand pounds. It's a given you need a heavy tractor in front of it in Kentucky.
Ninety percent of the time you can do fine with a two wheel drive. It's that ten percent that get you in trouble on even slight hillsides with surface moisture (or even very dry - read, slick) on your grass. You begin to put yourself and your machinery in some peril. Even if you are smart and quit while you're ahead in these situations, you're going to spend a good part of a productive day getting a stuck machine back out.
Not to mention the damage to one's ego. Yeah, of course I've done it...with 4WD...
I'm certainly not against two wheel drives. We got along with them for many decades. But admit it, don't you love these newer 4WD drives?
The 2815 (with the additional wing) is no finish mower, but I haven't noticed a lot of really uneven distribution of grass. Mine is set up with blade ring steel guards underneath and protective chains all around. Which should even add to disruption of airflow. Any chance you might be allowing PTO speed to get too low to spread the cuttings? Hard not to back off the throttle when in a ditch though...I have a 2810. Mine will pile up the grass behind the main cutter and be clean under the wing. I got it to mow ditches. Yesterday was the first field I mowed. My 8 foot one will spread the cuttings much better.
Does yours do the same?
Mine could be “We mow steep, but our prices aren’t”One of the guys out here has this on his signs:
"We mow the deep and the steep!"
