The Adapter Saga Continues
/ The Adapter Saga Continues #41
just outa curiosity.....the lil knob that releases the adaptor from the shaft, I couldnt tell from reading all the threads, is it still in there? Not in there? was just wondering....IF it was still in there, rotate it with a pair of pliers?maybe it is a 1 side flat, 1 side round locking shaft? I dunno, just an idea.If it is not in yet, is there a piece of the spring in there yet? If you knocked it out with a hammer/punch, a piece coulda got broken off and stuck in there?
/ The Adapter Saga Continues #42
Woody,
All that has been removed.............no pins......no springs....that we know of
/ The Adapter Saga Continues #43
mark: spray the adapter with wd40, or such, spray it in every opening u can find. then after it has a chance to work for a bit, as u are prying, tap it robustly with a hammer. if it has not been off in a long time it may have formed a coat of rust, which can seem like a weld joint, hope u get it off.
/ The Adapter Saga Continues #44
the "spirit" of the tractor dont want to let go of it! Talk nice to it? lol, sorry....without seeing it, am at a loss here now.
/ The Adapter Saga Continues #45
Mark I figured it out.
Leave the lock pin out and drive the tractor in some secluded area where you will never go again or drive through a tall pasture you have to mow. It will fall off all by itself when you aren't looking. /w3tcompact/icons/hmm.gif Then you can go find it with your mower /w3tcompact/icons/grin.gif
/ The Adapter Saga Continues #46
I think CSAW is on the right path...Go buy a NEW adapter and a NEW grinder and wheel to cut off the old one. Go to great lengths to lie to the wife about the need and the cost.
Be sure the new gear is NON-REFUNDABLE!
The old adapter will fall off on its own as soon as you arrive home with the new stuff!
/ The Adapter Saga Continues #47
<font color=red>"The old adapter will fall off on its own as soon as you arrive home with the new stuff!"</font color=red>
Of course, it will take with it the PTO shaft and part of the casting.
<font color=blue>Go to great lengths to lie to the WIFE about the need and the cost.</font color=blue>
Ahhh !! I don't got one of those.
Which AT TIMES is a good thing.
/ The Adapter Saga Continues #49
Mark,
I'm still thinking debris is in the adapter.
Try placing a round magnet in the hole where the pin was and move the adapter back and forth / side to side. This might allow the debris (assuming it's metal shavings) to dislodge and attach to the magnet.
Someone else mentioned a feeler gauge (very thin metal strip). Insert between the adapter and spline to feel for debris and/or move debris.
/ The Adapter Saga Continues #50
If the pump ever wobbled around on the PTO shaft during use, the softer steel splines of the adapter may have mushroomed and are now wedging against the PTO shaft. Look at the bright side, when my first one did this it took out the pump bearings and cracked the pump case.
TANK MANIFOLD (A60736)
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2008 FORD F-350 SUPER DUTY (A60736)
2008 FORD F-350...
2025 Miva Va15 (A60463)
2025 Miva Va15...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
