The Adapter Saga Continues
/ The Adapter Saga Continues
John,
In all honesty, In this particular situation, you make a very good point. For you see. I have no other implements (at this time) that would require the PTO except the afore mentioned backhoe.
So, I guess I really Don't need to remove the adapter. Except for the fact that it has now become a quest.
glenn,
I have the PERFECT reason / argument for the use / requirement of a PTO pump.
My JD 950 came with it and it has no rear hydraulic connections. /w3tcompact/icons/laugh.gif /w3tcompact/icons/smile.gif
I suppose I could always trade !!! Hmmmm !!!!
/ The Adapter Saga Continues #23
Glenn...
One of my best friends is an attorney...
...and I must admit both of you guys do have a great sense of humor and can so subtly stir up the pot... /w3tcompact/icons/grin.gif
(without any give away expressions on your faces...)/w3tcompact/icons/smile.gif
/ The Adapter Saga Continues #24
Mark, I have to wonder if the application of heat to the adapter will help. As these things become a real challenge we would all love to see you triumph over the adapter.
/ The Adapter Saga Continues #25
Ahhh a picture is worth a thousand words. If its as loose as you say try EdKing's advice and put a gear puller on it. If there is debris in the groove at worst you'll just markup the shaft or adapter a little. As far as heat goes be very carfull of the shaft seal, a solution to one problem could lead to a bigger one /w3tcompact/icons/frown.gif.
/ The Adapter Saga Continues #26
Mark,
Have you had this adapter off in the past? Or is this the first time you've tried to remove it?
Jerry,
This is the first time. I have only owned the tractor / backhoe for 1 year and just recently got brave enough to remove the backhoe.
The local dealer where I bought the tractor had installed a new clutch just before I found it and bought it, which meant that they had to remove the backhoe in order to split the tractor. In fact it was in his shop that I first saw the JD 950 and it was split then.
Not knowing much at all about the path of the PTO shaft through and into the tractor housing. I don't know whether or not the adapter would have had to come off, in order to split the tractor or did they do as I did and just remove the pump shaft from the adapter, leaving the adapter attached to the tractor.
Out of curiosity, the next time I am over there, I will go down to the repair shop and talk to the service tech that is there, for he is the man that did the new clutch installation and such.
Whatever it is that is not allowing the adapter to slide off has some strength to it. I am 6'2' and 230 lbs and with me applying enough strength to flex a heavy 3' wrecking bar, the adapter will not budge. I also don't want to apply to much force back on the rear end housing while prying against it.
I am going to have to make sure that I clean everything real good and look for a possible pin, I haven't seen one but it is worth another look.
/ The Adapter Saga Continues #29
Mark,
Then there's still something in there holding it on.....no other holes? Somewhere a roll pin has been driven in?
/ The Adapter Saga Continues #30
Of course a good fit on a roll pin and it wouldn't slide back 1/8" usually.
/ The Adapter Saga Continues #31
Post a picture of the pin. Maybe it will give us some insight.
/ The Adapter Saga Continues #32
Of course there could be a hole through the PTO shaft as some have said with debris stuck in it (small stone etc). That may give you the play your seeing but keeping it stuck on.
Ah well I know were all looking forward to the end of the mystery and none more than you!
/ The Adapter Saga Continues #33
I would try wiggling it back and forth while trying to torque it off with the puller. It could be that the PTO has worn a groove in the adapter. The adapter is probably soft compared to the PTO shaft.
I'd split the adapter with a grinding wheel and get a new adapter, it might cost $50 or so but, it will save you $$$$ in aspirin.
BTI
/ The Adapter Saga Continues #34
Mark,
At this point in time, I'd consider getting hold of the dealer you bought the tractor from first, then the back hoe manufacturer.
Explain the problem to them and get their advice. Also, tell them what you've done already and what you may be planning (that is, the gear puller or the allthread trick).
In one of the posts, you mentioned this was the first time you dropped the BH off. That adapter may have been stuck on long before you bought your tractor.
Since you've tried a prybar, I don't think a puller is going to help either. Personally, I think you'll end up cutting the adapter off with a grinder.
Since the adapter does wiggle, it's unlikely the cause is rust. A burr may well be the issue (with precision machined parts, it doesn't take much of a burr either), but since your prybar actually started bending during your attempts, that would have to be one heck of a burr...of course, I'm assuming you didn't "cock" the adapter when prying and you did pry from differing areas of the adapter.
It's possible this adapter was buggered up before you bought the machine. You just didn't notice it until recently.
When you contact the backhoe manufacturer, you may want to ask about replacements adapters, since it is possible you'll end up destroying it to remove it.
GOOD LUCK!
/ The Adapter Saga Continues #35
I'm a newbie here on the forums (still trying to think up a good name before I register), and a newbie with tractors in general, but......
Have you tried using a long feeler guage through the inside of the adapter and out between the adapter and the spline shaft? If you can get one through, you may be able to determine where exactly the hang-up is. Perhaps then you could use a diamond-wire cutting blade on a coping saw or something of that nature to cut through whatever is holding the adapter on the PTO.
Just my .02 dollars.
/ The Adapter Saga Continues #36
<font color=blue>..., I can now look through the hole the pin was in....</font color=blue>
Mark...
Take a punch the same as the "outside" diameter of the "hole" you can see through and make sure it passes through the shaft... is it possible you have a "large" roll pin in that hole and you could be looking through the "center" of the roll pin itself... (and the roll pin shifted up/down inside the hole?)
Also take some emery cloth or steel wool and go over the outside of that adaptor... you have to be missing a "concealed" or blended in roll pin... it will be placed near the outside edge (implement side) of the PTO tractor spline...
When you can flex a crowbar and not move it... it is not some metal burr holding it... have one of your kids or somebody with "eagle eyes" look closely... at all sides/angles... not just from the top...
I know you'll find and fix the problem this weekend... I can feel it in my bones... /w3tcompact/icons/smile.gif
/ The Adapter Saga Continues #37
I bet something got into the groove around the pto shaft. Why don't you try turning the shaft so the the hole that the pin was in is at the bottom and run flexible wire around the groove to see if you can push whatever it is around to the bottom so you can remove it. This is about the only logical explanation that I can see for your problem.
/ The Adapter Saga Continues #38
On our old farm tractor we could push the pto shaft further on the shaft than the retaining pin slot and would have to pull it back to let the pin catch. you might see if the adapter will push further on the shaft. A light tap with a hammer might move it forward and let what ever is binding it come loose.
Well I have yet to figure out how to get the adapter Off. Since I have no other PTO powered attachments at this present time,it is not imperative at he moment to get it off.
So rather than destroy it by cutting it off, I will just be patient and figure out what is holding it on. As for right now, I have reinstalled the backhoe so I can move it away from the lawn and to someplace where it won't kill the grass while sitting idle.
/ The Adapter Saga Continues #40
Mark - This is getting to be like a soap opera... But you have me hooked... so keep us posted on what you find!
New Holland 851 Round Baler (A66408)
New Holland 851...
20ft Driveway Gates (A65579)
20ft Driveway...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
Skid steer Backing Plate (A62679)
Skid steer Backing...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
YALE FORKLIFT (A63291)
