cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!!
/ cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #21
in the end, double check the length of the shaft, it almost sounds as though it might be too long and get additional force applied horizontally potentially causing a binding in the splines and/or lock ring - most will stick to a degree, but typically come loose with a bit of giggling.
/ cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #22
I have one you have to pull the outer ring back then push whole assembly forward (while holding the outer ring back), to allow the engaging balls to release
/ cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #23
My Wallenstein chipper is my only PTO implement. Believe me - there are those times when the Gods are truly against me. I have my PTO shaft bundled up in clean rags and stored in my work shed. So when I need it - it's nice and clean. Even then I will spray both ends with WD40.
/ cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #24
I found the magic ointment after a bout with one of those wonderful couplers, the high pressure grease you use on the FEL joints, just squirt a finger full then work the grease into the bearings with the release collar back.
/ cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #25
Glad it worked out. I had one stuck once with a new mower. Clean, lubed, and shiny. It finally popped off but not before I had damaged and warped the pull-collar. A machine shop repaired it but the guy said it looked like someone had beat the crap out of it. :rolleyes: Duh, that was me I confessed.
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A60430)
2007 FORD F750 XLT...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
(INOP) 2017 KUBOTA X1100C RTV (A60430)
(INOP) 2017 KUBOTA...
