cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!!
   / cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #21
in the end, double check the length of the shaft, it almost sounds as though it might be too long and get additional force applied horizontally potentially causing a binding in the splines and/or lock ring - most will stick to a degree, but typically come loose with a bit of giggling.
   / cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #22
I have one you have to pull the outer ring back then push whole assembly forward (while holding the outer ring back), to allow the engaging balls to release
   / cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #23
My Wallenstein chipper is my only PTO implement. Believe me - there are those times when the Gods are truly against me. I have my PTO shaft bundled up in clean rags and stored in my work shed. So when I need it - it's nice and clean. Even then I will spray both ends with WD40.
   / cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #24
I found the magic ointment after a bout with one of those wonderful couplers, the high pressure grease you use on the FEL joints, just squirt a finger full then work the grease into the bearings with the release collar back.
   / cannot remove PTO SHAFT FROM TRACTOR — RESOLVED!!! #25
Glad it worked out. I had one stuck once with a new mower. Clean, lubed, and shiny. It finally popped off but not before I had damaged and warped the pull-collar. A machine shop repaired it but the guy said it looked like someone had beat the crap out of it. :rolleyes: Duh, that was me I confessed.
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
