Tc33d w/ 7308 loader valve question
/ Tc33d w/ 7308 loader valve question #1
Mjl1226
South shore, Massachusetts
New Holland TC33D
Does any one happen to know the actual prince model number for the loader valve for a new holland TC33D with a 7308 loader? New holland dealer wants 1300.00 plus. If I can figure out what the actual prince #is I can get it for 300.00.
Any help would be great.
/ Tc33d w/ 7308 loader valve question #2
If you can't get number then see if you can get schematic of valve in question then compare it to Prince line of valves might be some work involved but to save a grand?
/ Tc33d w/ 7308 loader valve question #3
I doubt you'll ever find a definitive answer to that question. Why does your valve need to be replaced?
there are several reasons.
It would appear that at some point in time the prevoius owned had taken it apart for some reason and user the wrong screws to wold the bonets onto the valve body and they did not use any type of lock washer or thread lockso the regen bonet fell completly off and the float bonet only had one screw holding it on and it was almost completely backed out.
when I did the recomended a hydraulic test on the loader to see if the piston seals were shot I have hydraulic fliud coming from lines that I should not. For example if I disconect the lines going to the cylenders to curl the bucket and then push the joystick to dump I have hydraulic fluid flowing out of the feed line to curl the bucket and vise versa.
/ Tc33d w/ 7308 loader valve question #5
Show us a picture of all sides, top and bottom and we should be able to figure which valve you have.
Prince has three loader valves, the LVT, LVS, LVR.
Any numbers of name on the valve?
/ Tc33d w/ 7308 loader valve question #7
How about them pictures?
Prince typically pin stamps directly on the product or attaches a tag with the model #, date of manufacture, and a serial # or some combination that will include the model #.
Are you sure it is a prince valve?
JJ I have had the valve out twice now to find numbers. The only number not ground off the valve is the casting number which comes back as an LVT casting. The original valve is a custom made valve by prince for new holland. Prince won't even answer any questions about the original valve. "It's a breach of our contract". So the treat it as an unknown valve and we start from scratch. The prince rep came up with an LVTRG5BC7.
