Swollen Ford Lug nuts
/ Swollen Ford Lug nuts #83
They allow you to use your impact driver with no danger of over torquing. No strong arm work for this old man.
I see. I have a bunch of nice torque wrenches but it may be nice just to "whiz" lugs on with an air gun.
/ Swollen Ford Lug nuts #84
I use a Makita impact w/auto stop that can be set anywhere from 'Stop at first 'impact' (~ 10ft/lbs) , to full on 'try to snap it off' (~450+ft/lbs). Usually run them up on the low setting, then again at the next higher when the tires are on the ground (~60lbs), then final torque by hand.
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A61307)
2023 Takeuchi TL6R...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
VOLVO SD115B SMOOTH DRUM ROLLER (A62129)
VOLVO SD115B...
2012 John Deere 6170R (A57148)
2012 John Deere...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
