Swollen Ford Lug nuts
/ Swollen Ford Lug nuts #83
They allow you to use your impact driver with no danger of over torquing. No strong arm work for this old man.
I see. I have a bunch of nice torque wrenches but it may be nice just to "whiz" lugs on with an air gun.
/ Swollen Ford Lug nuts #84
I use a Makita impact w/auto stop that can be set anywhere from 'Stop at first 'impact' (~ 10ft/lbs) , to full on 'try to snap it off' (~450+ft/lbs). Usually run them up on the low setting, then again at the next higher when the tires are on the ground (~60lbs), then final torque by hand.
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
17109SFL (A61569)
17109SFL (A61569)
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
