Swollen Ford Lug nuts
/ Swollen Ford Lug nuts #83
They allow you to use your impact driver with no danger of over torquing. No strong arm work for this old man.
I see. I have a bunch of nice torque wrenches but it may be nice just to "whiz" lugs on with an air gun.
/ Swollen Ford Lug nuts #84
I use a Makita impact w/auto stop that can be set anywhere from 'Stop at first 'impact' (~ 10ft/lbs) , to full on 'try to snap it off' (~450+ft/lbs). Usually run them up on the low setting, then again at the next higher when the tires are on the ground (~60lbs), then final torque by hand.
2022 EZ-GO ELITE...
2017 Case CX145D (A62177)
2017 Case CX145D...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
