Do I need a torque multiplier to get these nuts off?
   / Do I need a torque multiplier to get these nuts off? #11
Heat the nut. Don't worry about damaging any seals, the seals are to far away from the nut with to much steel in between the two. It is not uncommon to replace (sacrifice) these 4 bolts.
   / Do I need a torque multiplier to get these nuts off? #12
Another vote for heat. I take mine on and off annually to sharpen blades just to make sure they will come off. Could sharpen blades on unit, but get better edge in vise.
   / Do I need a torque multiplier to get these nuts off? #13
Use heat on the bolt. Don't worry about messing up something--it's a brush hog that's built like a tank.
As a last resort, tilt that beast up so you can get to the stump jumper and use an angle cutter with cutting blade to cut through the head of that bolt such that you cut the mower blade off. Then cut the shaft of the bolt to get it off the stump jumper.
Good luck.
   / Do I need a torque multiplier to get these nuts off? #14
You're using impact sockets right? A lot is lost through extensions and unsufficient sockets too. But yea, heat is #1 thing to use. Ask any automotive shop, most guys there should be torch pro's due to the amount they get used.
   / Do I need a torque multiplier to get these nuts off? #15
OK, I'll bore you with another vote for heat but...use an acetylene/oxygen torch and heat the nut to a dull red. Then throw the impact wrench on it and the nut will spin right off.
Heating those nuts will not damage anything. The seals are far enough away as others have mentioned. However, the area, nuts, and bolts will stay very hot for a long time. Best let them cool down on their own. Have lunch, a few beers, or whatever for an hour or so.
On the impact wrench...some of the cheaper wrenches, even in 3/4" or 1", won't do the job like a 1/2" quality (read $$$) impact wrench. Been there, done that.
Edit: And when you put the nuts back on just let the impact wrench rattle on them for a couple of minutes. The torque will be perfect then. :thumbsup:
   / Do I need a torque multiplier to get these nuts off? #16
If heat does't work, cut them off with a torch or grinding wheel. First time I took off my LP blades I had to use heat. My manual says use new bolts and nuts each time as the self locking threads are one timers. If forced to reuse I would put back on with "Locktite". I keep a spare set of blades, bolts and nuts. My 3/4 drive 6 point socket and torque bar work good. Run them up snug w/a !/2 drive impact w/ adapter and torque down the nuts with the bar. My LP nuts are 1 7/16 for some reason.
   / Do I need a torque multiplier to get these nuts off? #17
stop fartin around and cut them off. im an old man but as my old man would always say, "use your head for something other than a hat rack"
   / Do I need a torque multiplier to get these nuts off? #18
A mapp gas torch is cheaper than o/a for small projects. Lowes has an oxy mapp setup you could try too.
   / Do I need a torque multiplier to get these nuts off? #19
That's not a very handy place to cut something off. I have a 600 ft pound impact wrench that I run at 150 PSI. If the bolt or nut has Loctite on it the impact wrench isn't going to budge it. That is what Loctite is supposed to do. It doesn't take much heat to soften Loctite. If I remember correctly Loctite softens at a little over 400 degrees.
   / Do I need a torque multiplier to get these nuts off? #20
It looks like heat is your best answer.
If you are still nervous about it, go down to a welding supply shop and get a 400 or 450 degree "temperature crayon". Make a mark on the bolt head, and heat until the mark melts.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52128)
2023 New Holland...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
7022 (A50322)
7022 (A50322)
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
