Subcut Maximum Towing Capacity
/ Subcut Maximum Towing Capacity #21
So when you're pulling something heavy and precious you have to take extra precautions.
Wm
yep.. i have a harness made up for my ford 5000 to use a spare hoppy brake controller on my trailer as well. min mounts to the fender. i one time toyed with making up a pin switch so it was auto magic with the rakes.. but now I just use the panic switch if needed.
soundguy
/ Subcut Maximum Towing Capacity #22
I would expect to be able to tow about 2x the lift capacity of the 3PH. For example, my tractor could safely tow 4800 lb. I don't mean this as a hard and fast rule, but only a rule of thumb.
/ Subcut Maximum Towing Capacity #23
To add to this. It's not just the brakes that limit SCUT towing capacity.
I know my little 1830 has enough braking to tow an 8000 lb camper down a slight hill. The problem, is that the wheelbase is so short, and it's weight is so small, that that camper will jack-knife the SCUT in the blink of an eye.
I can tow that same camper around all day long, on flat surface no problem. For me - it's the wheelbase that is the limiting factor.
/ Subcut Maximum Towing Capacity #25
Milkman: M? I think a C would do it.
Wm: That's a beautiful H. I am trying to locate the one my father bought on the black market in 1946 when he returned from the Army Air Corps. Daddy loaned it to a down-on-his-luck neighbor in the 1960's and would not let us kids ask for it back.
Found this while browsing the new John Deere Sub-Compact Tractor Operator's Manual. There is no maximum towable mass specified but it does give pretty clear guidelines:
1.5 X tractor weight for unbraked load and 4.5X tractor weight for braked load. Sounds pretty sensible to me and I imagine pretty much the same guidelines would apply to other subcut tractors.
John Deere 1023E/1026R Sub-Compact Tractor.
Stopping distance increases with speed and weight of towed load, and on slopes. Towed loads with or without brakes that are too heavy for the machine or are towed too fast can cause loss of control. Consider the weight of the equipment and its load.
If towed equipment does not have brakes........... do not tow loads more than 1.5 times the tractor weight.
If towed equipment has brakes........... do not tow loads more than 4.5 times the machine weight.
Ensure the load does not exceed the recommended weight ratio. Add ballast to recommended maximum for machine, lighten the load, or get a heavier towing unit. The machine must be heavy and powerful enough with adequate braking power for the towed load. Use additional caution when towing loads under adverse surface conditions, when turning, and on inclines
/ Subcut Maximum Towing Capacity #27
Towing down the road and moving something around you property is a totally different thing. For example my uncle has a 25,000# boat that when he first bought it I moved it to and from the lake with my F-350 diesel but he moved it in and out of his shop numerous times with his V6 Toyota Tacoma. With my 25HP tractor I move boats and trailers in excess of 25,000# around the boat lot, not every day but I do it. I do move 10,000# to 16,000# boats weekly but this is all at slow speed on level ground in a controlled environment.
Chris
Finally purchased my Yanmar EA 2400 which is identical to the Cub Cadet SC 2400 and was able to resolve my towing question for the 2400. The Yanmar manual, although almost word for word identical to the Cub Cadet manual, does have some information regarding towing for the 2400 which IS DIFFERENT from that in the Cub Cadet manual even though they are IDENTICAL tractors.
Interestingly it recommends only towing with the 3 point hitch.
Yanmar EA 2400 Manual
Do not attach or use towed equipment by a drawbar or a drawing device/Attachment. Use of the drawbar.... is not allowed in this tractor.
It does also list a much higher maximum towable mass:
Implement Capacities page 4-1
Maximum Gross Towing Load 800kg (1764 lbs)
versus the Cub Cadet:
Cub Cadet SC 2400 Manual
Maximum Towing Capacity 300kg (661ibs)
I wonder is the Cub Cadet number a misprint or a conscious decision by Cab Cadet to understate the true capacity for some reason (legal?)?
Mark
10'' PALLET FORK EXTENSIONS (A61572)
10'' PALLET FORK...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
Lifts (A61567)
Lifts (A61567)
iDrive TDS-2010H...
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
