Buying Advice sub compact or compact tractor?
/ sub compact or compact tractor? #21
I haven't owned a Kioti, but one of the dealers I used in the past had a Kioti dealership and I was impressed with what you were able to get for the money. Since you are planning on moving some dirt and building a mini track, my only recommendation would be to get the heaviest tractor you can afford. You will lose traction way before you lose HP. On my first tractor purchase, I was all over the place on what to get. Fortunately my dealer allowed me to try out several models on my property to see how they worked out. In the end, I wound up with the heaviest one I could afford (Massey Ferguson 1445) - and due to the rocky terrain - it was still too little tractor to do some of the things I wanted to. At 3800 lbs before loading the tires, however, it was much more capable than the smaller models I tried.
You haven't mentioned what the soil conditions are like at your place. Depending on how rough it is, you might decide to buy what you would need in most instances, and then rent bigger equipment when you need it. At my new place, my needs were much different than the past - so I ended up buying a heavier 45 HP 2WD utility tractor (for the same price as a SCUT) with only the implements I need on a daily basis. For the bigger projects, I can rent equipment that is perfectly suited to the job without feeling guilty about it.
I will say that you are lucky to have a good Kioti dealership near you, since they offer such good value. If I had one near me, I would have definitely given them a good look.
/ sub compact or compact tractor? #22
This is sort of redundant to my earlier post. But if you never expect to dig out stumps, dig deep holes, etc. You don't need a backhoe. That is your decision.
The FEL -- you don't expect to move much ever, that again is your decision.
So go and buy the basic tractor with just a finish mower and/or a bush hog.
I have lived out in the hinterlands between Columbus, Cincy, and Dayton for more than ten years now. I can't name the number of times that I stopped or slowed down when I saw tractor for sale. Almost none had a FEL or the seller wanted +$10K for the tractor, with the added stuff.
If it had no FEL, I always looked at the cost to add the hydraulics and such and the numbers didn't work. So I could buy an MTD piece of cratp for $1K at Wal-mart with a 38" deck. It did the basic -- cut the grass and generally lasted 2-3 seasons. Pay $4K with nothing extra other than a wider deck for something used. I could buy a ZTR for that. Or spend +20K to get essentially all I need, probably for life. About the only add-on that I have bought was some pallet forks for stuff that won't fit in the FEL.
So the choice is yours. But you definitely want the hydraulics installed.
/ sub compact or compact tractor? #23
Another 2 cents worth of opinion re: SCUT & CUT - think about tire size if you are working in a rough field.
The SCUT's will do a whole lot of work but typically have what I feel are "nervously" small tires.
The CUT's tires are typically larger in diameter anf therrefore better going over rough ground (deeper holes & deeper mud).
I went with a CUT for just that reason.
"Nuther" comment - if this is a first tractor purchase, by a used machine and learn what these can really do before dropping a load of money on what you think might be a good idea!
Then you'll buy smarter.
/ sub compact or compact tractor? #24
I thought about used briefly till I saw what everyone was asking for used equipment. New is only a few thousand more than a 4-5 year old tractor with 300 or more hours in most cases. I did buy my Kubota B26 used from an individual who had also bought it from the original owner. Between the 2 people they had put 60 hours on it in 3 years and it was about $10K cheaper than a new one. I bought my Kubota RTV used from original owner also at 2 years of age and 45 hours for $4K savings. If you find some deals like that, then used isn't bad, otherwise, just stick with new especially if you need to finance it. New can be had at 0% interest in many cases compared to 7% or more for a used one.
As for size, 25-30 HP should handle all you need to do in a CUT size. I don't think a post hole digger will work on SCUT as they wont raise the drill off the ground.
I love my back hoe and wouldn't be without one. My only regret is not getting one 3 years earlier. I don't use shovels to dig holes for planting shrubs anymore or wheel barrow to haul material either. My tractors and my Kubota RTV do all the work for me now. Oh and if you decide to get a back hoe, don't forget to get the hydraulic thumb on it. Adding a thumb to the hoe, is about the same as the difference in what you could do with/without your own thumb.
One thing that you will find that is not any difference between your riding lawnmower and the tractor is that it isn't going to ride any smoother. The tractor suspension (or lack thereof) is just like your riding mower so you will feel every bump. You may get a better set with some shock absorbing springs to help out a bit, but they are still rough so you may not be able to travel any faster with the tractor than with the mower.
/ sub compact or compact tractor? #25
we have 3 acres, former wheat field, adjacent to wildlife management area/lake. debated between skidder and tractor to develop lot into full-time home (build house/polebarn, build driveway, landscape/drainage, plant/mow lawn, and blow/blade snow, etc). i dont have trees like you, plus i did/do have a neighbor with a skidsteer that really likes to play on it! I decided the tractor would be more versatile for the upcoming projects. So, how big? I bought a used JD2305 scut, with blower, 60"mmm, and have added a FEL, box- and rear-blades. For the dirt-moving reshape landscape, my neighbor did it in about 8 hours - would've taken me weeks with a rental, or months with my little tractor. But i've cut bushels of grass, moved many tons of gravel & rock, blown two seasons of snow and maintained the gravel road & driveway with the combo since.
Hindsight: would've been nice to have a beefier tractor, maybe 30hp, but then i probably wouldnt mow with it (add ztr). I think this is a perfect setup. The little guy works like a horse, fits in the garage for winter warmth (with the front blower and rear blade mounted), fits on the trailer i use for everything else and isn't too big on my little spot.
I don't have trees to contend with, and my other neighbor has a scut with a bh attachment, so i may host some bbq parties for him to help with my retaining wall(s). Now, if i didn't have these two guys itching to move dirt with their toys...
/ sub compact or compact tractor? #26
My future plans are to dig a small pond, mini bike track, post hole dig for a new fence and pole barn, add a separate driveway, dig out for patio, dig around house and redo storm drains along with the typical gardening stuff and whatever else I can think of over the next several years.
Thanks.
I took a quick look at the specs on the Kioti tractors. For the uses you described above, honestly, I think I would be looking at something like the CK20s or CK25. The CK20S appears to weigh 2000+ lbs, while the CK25 weighs 3,000+ lbs (if you load the tires on both it will add a good amount of weight). I'm not sure about the price difference between the two, but even if they were the same HP, I would still like the extra weight. Since you already have a JD x540 for mowing, I don't know if you would ever be happy with a smaller SCUT, since in my opinion their big benefit is that they make good mowing tractors for tight spaces, while also giving some functionality of having a loader and some 3pt attachments. When I was looking, it didn't seem like there was a big price difference between SCUT and CUT.
I don't know about the Kiotis, but I know that when I was looking at the John Deere 1 series, they would not take a full sized post hole digger - I'm not sure about other SCUTS.
To give you an idea of the earth moving capability of something like the CK20s, here is a video that I came across on youtube. For all I know, it might be someone from the forum?
Digging a pond with a Compact Tractor - Kioti CK20s - YouTube
/ sub compact or compact tractor? #27
Since it sounds like you have a lot of use for a loader I would look at tractors the size of a Kubota B3200. I would use it to smooth out your yard and keep the X540 to mow with.
/ sub compact or compact tractor? #28
Welcome back Roger.:)
/ sub compact or compact tractor? #30
The CK20 is not a SubCUT. It will handle standard CAT1 implements, including a PHD. However, the OP's situation is similar to mine: 2.5 acres, a JD425 for mowing, and had a need to move earth, and lots of it. I went in thinking CK20. Test drove it and it's bigger brother CK25. I chose the CK25 in gear because:
Only $1500 more
About 50% heavier
way more hydraulic flow
extendable 3PH
Shuttle shift manual tranny gave me maximum power to the ground (shuttle not available on a CK20). HST mandates more HP: CK30 or CK35.
Live PTO
1 ft. Bigger bucket
1 ft longer backhoe (reach is king with BHs)
If you want a digger, an earth mover, a trencher, a road maintainer - there are few, if any, better in this HP class than the Kiotis. With loaded tires, my CK25 TLB weighs in around 6100 lbs or so. It's a beast. I have moved well over 1000 tons of fill dirt and stone with it, and several hundred tons of manure, mulch, concrete, brush, and other materials. I dug hundreds of feet of trenches for drain lines and retaining walls, I've removed several huge stumps. Buried a 500 gallon propane tank. I've installed 800 feet of fence. Built a small pond. excavated for a patio. Move snow. Chipped brush........ These things are so useful!
/ sub compact or compact tractor? #31
Sorry if I gave the impression that I was implying that the CK20 was a SCUT. I was actually trying to say that going with a CK would be better than a SCUT because it could handle a full sized post hole digger as opposed to the JD SCUT that I had looked at.
Gittyup, your setup looks great. After having both hydro and gear, for my purposes, I see nothing wrong with going gear if it gets you into a larger tractor. My last tractor was a hydro and my most recent tractor is a gear (mine is not even a shuttle). After a little practice with it, I can't say that I miss the hydro...
/ sub compact or compact tractor? #32
Well using the BH in my neck of the woods I started hitting clay about 5.5 feet down for my burn pit. But it was definitely a good video.
I dug a growing tree out next to my house's foundation with a combo of the BH and FEL. No added damage to the foundation. His digging out a pond I could probably do with my Max25, if I felt like it.
Realistically in the SCUT/CUT size tractors they have moved into the difference between a Ford F-150 and Chevy 1500 or Dodge Ram 1500. Each one has a little more emphasis on speed compared to cargo capacity compared to price. But each will do the basic job of running stuff around. So it is a matter of doing the research and deciding which combo is the best fit for you needs.
In my case I saw a Kubota ad and went to that dealership 25 miles away and found out they had Mhindra's as well. The numbers for the Mahindra were cheaper than the Kubota's for the equal capacity. Years prior I had gone to the Mahindra dealer 3 miles away and the financing didn't work. This time it did.
There are some brands I wouldn't buy just because I have never hear of them. To be frank, until I came here I never heard of Kioto. But JD, Kubota, IH/Case, Mahindra, and Ford/New Holland tractor dealers are spread around the area. So whatever decision is made you need to look at what you want to do with it, support for your equipment, and what you can afford.
And then part of the decision is what equipment you want off the bat (and financing) and what you can buy later.
/ sub compact or compact tractor? #33
That is someone on this forum. That's TSO who recently upgraded to a Cabbed Massey 1648 I think.
/ sub compact or compact tractor? #34
Yup that was my old CK20s HST. Very capable tractor. I wouldn't mind owning one again, or even a slightly smaller SCUT, in addition to my 1648.
The CK20s had a couple small warranty repairs, but was otherwise very good. Only complaint was the 2spd HST ... would have benefited from being 3spd.
I think I'm going to wait till the new incentive programs come out in spring then maybe I'll go kick some more tires. I'll see if they let me try a couple out at my house but probably not till I'm fully in the market to purchase, I don't really want to waste they're time until I know I have the OK from the boss and my conscience to buy such an expensive toy.
Also take some more time to decide what I want to do myself vs. maybe hiring out since a family friend does have an excavating company. Sure would be nice to do everything myself but at the end of the day everything comes down to $.
Thanks for all the help guys.
/ sub compact or compact tractor? #36
I've got one thing to say to set your conscience at ease. I felt the same way that you do about spending a lot of money on a tractor, but I am really shocked at how well these tractors hold their value. You really don't have to view it as an outright expense because it is nothing like owning a car that devalues very quickly.
/ sub compact or compact tractor? #37
That's a really good point, especially if you're a smart shopper and you get a good starting price to begin with. For example:
Bought a Kioti CK20s, used it for about a year & 200 hrs. Sold it for about $1000 less than I paid for it.
Bought an LS R4041 Shuttle. Used it for a few months & 50 hrs, traded it back to the dealer, so I lost a total of $1000 on it.
Bought an LS R4047 HST. Used it for 8 months & 150 hrs, sold it for about $1700 less than I paid for it.
Then I bought my Massey 1648 HST Cab.... hopefully I'll keep this one for awhile ;) but if not, I got it for a great price, so I probably won't lose much.
So, long story short, in 2 years, I've put about 400 hrs on a tractor, for about $3700. So, in a sense I've leased/rented a tractor for $155/month, or about $10/hour of use. I doubt I could have actually rented a machine for all that time for the equivalent of $10/hr ... and in the process, I learned alot about tractors, how to use them, all that stuff.
So yeah, don't worry too much about "losing money" because your productivity goes way up with a tractor!
/ sub compact or compact tractor? #38
Not only does mine hold value, but it works its *** off and save me literally thousands of dollars a year on labor, chiropractors, landscapers, and mules.
/ sub compact or compact tractor? #39
I agree when I started looking for a used 4x4 tractor with a loader all I found for 10 grand was to small or really showed there age.
Ron
/ sub compact or compact tractor? #40
Not to mention, it's at your disposal, 24/7, whereas, a rental would only be available when the rental place is open. As an example, say your water line blows on Saturday night and needs to be dug up and replaced. In 10 minutes, your warmed up and ready to go. Rental unit may not be available until Monday morning.
In addition, the longer you keep it, the less per hour it will cost. We bought a new '04 CK25, put 1,188 hours on it and traded it in 2013 for $4,900 less than we paid. $4,900 / 1,188 = $4.13/hour. So I agree, losing money is probably not a big issue. :thumbsup:
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
(APPROX. 500), GALLON FUEL TANK (A62131)
(APPROX. 500)...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
2844 (A58376)
2844 (A58376)
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
