Stupid Things I Have Done
   / Stupid Things I Have Done #681
So after spending an hr+ last night eventually getting what my state considers vintage snowmobiles running. Spent over an hr on a old skidoo 500 with a shady tree backwoods 136" track conversion. Anyways couldn't get that thing running, checked spark, good to go, so fuel problem, ended up changing out primer, replacing spark plugs anyway, half the fuel lines with new tygon ones,
, about to remove carbs and do a compression test when I finally realized I shut off the fuel valve last year turned it on, and voila runs like a 29 yr old snowmobile should. šŸ˜‚ Figure that's definitely a stupid thread worthy revival.
Nice! :ROFLMAO:
Reminds me of my tractor dying in my yard and would not restart. Starter wouldn't even click. Tried everything to get it to turn. Nothing. Bought a new start. That wouldn't spin either.....
Realized I'd bumpy the PTO switch and it won't start with that on.
:sneaky:
   / Stupid Things I Have Done #682
Sat there scratching whats left of my hair, been a good part of a year since i messed with it. Looked it all over, found small kill switch that was turned off. Forgot it was even there. The symbols next to switch made no sense, so i just turned it other way. Fired right up.
Maybe 10 years ago I'd replaced the engine in my log splitter with a Predator. The way the engine's mounted you can barely see the kill switch, reading it impossible. I've gotten caught a few times, either forgetting it was off, or thinking it was in the off position and turning it the other way.
   / Stupid Things I Have Done #683
I have the same kill switch on the predator on my log splitter. šŸ˜›
   / Stupid Things I Have Done #684
Mine has a Kohler. Same thing. You have to reach in with one finger to turn it on/off. Since I often shut the gas off and run it dry, I never know if the switch is off or on when I go to start it.
The Kohler on my sawmill has the switch tied in with the throttle.
Right now both engines are out of gas.
   / Stupid Things I Have Done #685
Typically the kill switch is just a normally closed switch. They are pretty easy to relocate. And, if you do, you might want to install a normally closed push button switch. hold it in until the engine dies, and as soon as you let go, it is ready to run again.
   / Stupid Things I Have Done #686
After cursing the plasma cutter for 5 minutes because it wouldn't cut and changing the torch consumables, I gave up and decided to use the torch.
That's when I discovered I didn't attach the ground clamp.
   / Stupid Things I Have Done #687
Recently while mitigating rust and installing aftermarket rocker panel slip covers using stainless steel rivets and polyurethane sealant adhesive drilled through what was left of existing steel rocker with a cobalt bit got thru the steel wasn't being careful and drilled into the wire loom which is ran on the passenger side thru a raceway. Took out my cab marker lights. 😔. That's definitely stupid after the money I put into that truck. Btw on 2016 GMC 2500s the main wiring loom on raceway runs
On passenger side under the plastic door trim. Cobalt bits even duller ones go through steel better than most I feel even if you have to use a little muscle however once you get thru steel and aren't careful will go to thru the plastic raceway and subsequent wire like a hot knife thru butter in milliseconds so I suggest being more careful than I was for sure.
   / Stupid Things I Have Done #688
Had the same thing happen to me a couple years ago, dicked around with it for an hour or so before I discovered that I'd accidentally bumped the emergency shutoff button. Didn't occur since I rarely touch it.
Even the alleged pros screw up. Same snowmobile, had brought it into the dealer to get something done on it. Got it home, and the temp gauge would show it overheating after only a few minutes of riding. Much troubleshooting showed up nothing, infared thermometer right on thermostat housing showed proper temperature (~185°). Replaced sender, no luck. Finally discovered that when they'd disconnected the battery, they'd only re-connected one of the two ground wires!! Hooked 2nd one up, all better.
Been there, done that, several times with our portable generator. A little freaky when the grid is down and it's 23F (cold for us).
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2018 John Deere Z997R (A53317)
2018 John Deere...
gps trailers (A56859)
