Stuck lever
/ Stuck lever #1
camillieri
Chester, NH
Kioti
I bought a Kubota B6100 and have a few questions. The high low shift lever won’t move. I don’t want to break anything so any ideas on this? It also is very noisy in one gear. The others are quiet.
Thanks
/ Stuck lever
I replaced the wheels and tires with the same size that were on it.
/ Stuck lever #6
So the transmission is not bound up? It drives fine just in the one gear that it is stuck in...
Is the 4x4 shifter working fine? Or have you tried taking it in/out and seeing if the hi/lo does anything different?
Lifting the tires off the ground and rocking them back and forth - just to see if things are bound up (or not)...
/ Stuck lever
Other than a noisy 2nd gear the transmission is fine. It’s only that the hi/lo lever doesn’t move so it can’t be shifted between ranges.
2022 EZ-GO ELITE...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
AGRIC AFMJ65 - 65" ROTARY TILLER (A64277)
AGRIC AFMJ65 - 65"...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
