Stuck lever
/ Stuck lever #1
camillieri
Chester, NH
Kioti
I bought a Kubota B6100 and have a few questions. The high low shift lever won’t move. I don’t want to break anything so any ideas on this? It also is very noisy in one gear. The others are quiet.
Thanks
/ Stuck lever
I replaced the wheels and tires with the same size that were on it.
/ Stuck lever #6
So the transmission is not bound up? It drives fine just in the one gear that it is stuck in...
Is the 4x4 shifter working fine? Or have you tried taking it in/out and seeing if the hi/lo does anything different?
Lifting the tires off the ground and rocking them back and forth - just to see if things are bound up (or not)...
/ Stuck lever
Other than a noisy 2nd gear the transmission is fine. It’s only that the hi/lo lever doesn’t move so it can’t be shifted between ranges.
Ammann AV33E Roller (A65579)
Ammann AV33E...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
3146 (A63117)
3146 (A63117)
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
International 37 Square Baler (A65640)
International 37...
