Stuck lever
/ Stuck lever #1
camillieri
Chester, NH
Kioti
I bought a Kubota B6100 and have a few questions. The high low shift lever won’t move. I don’t want to break anything so any ideas on this? It also is very noisy in one gear. The others are quiet.
Thanks
/ Stuck lever
I replaced the wheels and tires with the same size that were on it.
/ Stuck lever #6
So the transmission is not bound up? It drives fine just in the one gear that it is stuck in...
Is the 4x4 shifter working fine? Or have you tried taking it in/out and seeing if the hi/lo does anything different?
Lifting the tires off the ground and rocking them back and forth - just to see if things are bound up (or not)...
/ Stuck lever
Other than a noisy 2nd gear the transmission is fine. It’s only that the hi/lo lever doesn’t move so it can’t be shifted between ranges.
2019 Toyota Camry Hybrid Sedan (A64557)
2019 Toyota Camry...
International 490 Disc (A65640)
International 490...
2012 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2012 MACLTT 150...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
Kewanee 12A Cultimulcher (A66408)
Kewanee 12A...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
