Stuck lever
/ Stuck lever #1
camillieri
Chester, NH
Kioti
I bought a Kubota B6100 and have a few questions. The high low shift lever won’t move. I don’t want to break anything so any ideas on this? It also is very noisy in one gear. The others are quiet.
Thanks
/ Stuck lever
I replaced the wheels and tires with the same size that were on it.
/ Stuck lever #6
So the transmission is not bound up? It drives fine just in the one gear that it is stuck in...
Is the 4x4 shifter working fine? Or have you tried taking it in/out and seeing if the hi/lo does anything different?
Lifting the tires off the ground and rocking them back and forth - just to see if things are bound up (or not)...
/ Stuck lever
Other than a noisy 2nd gear the transmission is fine. It’s only that the hi/lo lever doesn’t move so it can’t be shifted between ranges.
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2018 Johnston C201 Compact Street Sweeper (A61572)
2018 Johnston C201...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
