Structural engineers needed for a beam calculation.
/ Structural engineers needed for a beam calculation. #21
The cheapest thing to do is buy an old flat bed tractor trailer, remove the bogies and landing gear, and use it for your bridge.
Been suggested before. No go. Have no way of getting it to the property, removing the axles or getting it near the creek it has to cross.
Without knowing the layout of the property or why you can't get one TO the place ....
Leave the rolling gear on and use one of your machines to pull it to the creek.
Use your Ex to dig holes on both sides to bury the undergear so the bed is at ground level.
Pull the tires and rims off and drop the rest into place. It shouldn't ever move.
Use the aluminum I beams for hand rails.
But I have no idea what these things cost or what your budget is.
/ Structural engineers needed for a beam calculation. #22
Call your local heavy wrecker and ask if they know of any that are available, they may know of some with a mangled undercarriage, or that are otherwise not good enough to put back on the road and they will have the ability to deliver them for you.
Aaron Z
I will give you a hint - You need to calculate the deflection to determine the safe working load. You are asking an engineering question with implied liabilities so not many people are going to put their neck on the chopping block for you on an anonymous user group. Hire a professional please and let them do the calcs. Safety first. If you dont know the answer then you probably shouldnt be doing the work.
I suggested the trailer because someone has already done the engineering for you.
Thank you for your advise.
I already have an engineered bridge, for the span in question, done by a professional using red oak logs. All I was looking for was an answer or advise on a specific beam that happened to be for sale near me. I am not familiar with aluminum beams. I have been in the building trade for 30 yrs and know how to calculate loads (live, dead, deflection) for dimensional lumber, laminate beams fitch plates etc.
/ Structural engineers needed for a beam calculation. #24
Curious how much do they want for the beams? I agree with the others that they are not big enough for anything of significant load, but wonder if they would make a fun project to build a bridge to walk across the creek, or even a cantilevered deck/sitting area that only goes half way across the creek.
/ Structural engineers needed for a beam calculation. #25
Since it doesn’t seem that anyone has given you the info you requested here is the formulae for calculating deflection at midspan, max bending moment and extreme fiber stress for a simply supported beam with a point load (w) at the center of the span (Roark, Formulas for Stress and Strain, 3rd edition, Chapter 8, Table 3):
Deflection=-1/48(wl^3/EI) at midspan (l/2)
Max M=1/4(wl) at midspan
Stress=Mc/I
You’ll need to know E (Young’s Modulus) for the aluminum alloy in question as well as ultimate tension capability (Ftu) and yield compression capability (Fcy). You’ll also have to calculate I (moment of inertia) for the beam cross section.
Formula for other loadings and support conditions can be found in Roark ( which is probably available on line somewhere).
You’ll have to determine applicability of formulae and suitability of material yourself:
Hope this helps
/ Structural engineers needed for a beam calculation. #26
Above formulas are correct. E - is 10,000,000 for aluminum.
You can calculate the I4 if you want, I just like using charts online that already spec it. Closest I can find is for a 8x5 beam....and that is 59.xx so yours is gonna be a little weaker.
So "assuming" a moment of inertia of 50....and a 25' long beam (300 inches) and 5000 pounds (half of your excavator)
(300 x 300 x 300 x 5000) / (48 x 10,000,000 x 50)
135,000,000,000 / 24,000,000,000
Deflection = 5-5/8" of deflection. Which is WAAAYYYYY too much.
IF you are familiar with building trades and construction, I assume you know what L/360 deflection is? Over a 25' span.....0.833 would be the MAX you want. And to not exceed that.....midspan point load of 740# is the absolute max. And all that assuming properly braced and all. Because a 4" wide beam is NARROW given the span.
No liability here, all I did was math and answered a question based on variables.
/ Structural engineers needed for a beam calculation. #27
For lumber house construction L/360 is used for finished ceilings to keep from cracking the plaster. L/240 is allowed for lightly loaded attics, L/180 for sloped rafters with no finished ceiling.
None of those really sounded to me like a bridge, really, so I went looking...
Apparently, AASHTO likes to use L/800 for simply supported highway bridges...mostly to keep people from feeling queasy as the bridge moves under their vehicle. The limits for cable stayed and suspension bridges are little more generous.
ResearchGate
/ Structural engineers needed for a beam calculation. #28
There's a few bridges where L/800 wasn't used. Ever sit in line on the Peace Bridge over the Niagara River crossing from Canada into Buffalo? It's often backed up because....well, that's the U.S. for you...anyways......when you're sitting there and the big trucks in the opposite lanes are rolling into Canada that bridge feels like it's going up and down a few feet. Definitely a queasy feeling.
...maybe that's the design, or maybe it's just another one of N.Y.'s 1837 bridges that are deemed structurally deficient? .
/ Structural engineers needed for a beam calculation. #29
I suspect any place where you are sitting still instead of rolling, you notice it more.
I was always surprised by the motion when stuck going nowhere on the elevated expressway in Boston before the Big Dig opened. Even a couple of inches (L/800 for 120' or so span) feels like a lot when you feel the whole vehicle doing it.
/ Structural engineers needed for a beam calculation. #30
Large bridges and large spans arent really a good comparison. This much shorter span can do fine with L/360. But thats only one piece of the puzzle.
Gotta account for stresses, and THIS is where the type of alloy needs to be known. And you do NOT want to exceed its yield strength. And you want to build in a good safety margin. The deflection isnt gonna be measurably different between different alloys.
Given the size of the beam.....and the L/360 limiting loading to under 750# for the beam, I dont see stress as an issue...
Just a quick calculation....750# being the load at midspan (limited by L/360)....and the 8" x 4" beam.....stress would be ~4500psi. Most aluminums are between 20 and 40ksi......some stronger, some weaker. But something shaped like an i-beam......I doubt 4500psi would be a problem. Deflection is your holdup.
L/800 would limit the aluminum beam loading to 333#
/ Structural engineers needed for a beam calculation. #31
One thing I haven't seen much mention of is the decking. Using the beams in question and adding a few hundred pounds of wood (or whatever) for decking, would it even support itself? Doesn't sound like it.
Some good ideas Eddie. The guy wants $800 for the 2 beams
Thank you all for the informative responses. Obviously I won’t be using them for this project. I didn’t know aluminum beams were that weak. I will go by the plans I had done for me utilizing (4) 14” diameter red oak logs, 2 on each side stitched together with rebar and sitting on a 2’x2’x8’ concrete abutments on either side. Decking is specd at 4”x12”. I had the engineer figure it on a max of 10k load.
Again, you engineers in the crowd, thanks for the informative responses.
/ Structural engineers needed for a beam calculation. #34
We might receive more snow than Woody does. Our roof and bridge codes are for 100psf and when we installed 42ft bridge, we used 18" beams on 3ft centers. I believe the live load was rated at 4000lbs that constitutes a truck crossing it. It was PE stamped. Ask if you care to see pictures of it. Oh and the decking was 4".
/ Structural engineers needed for a beam calculation. #35
:duh:Another thing to think about when building a bridge, insurance. Can a 120,000 lb. fire truck or even a 60,000 lb. tanker cross it in case of fire. I was a vol. fireman and we worried about bridges on private roads and driveways.
Even a bridge designed for 10k may be too small for insurance purposes.
Let us know how you make out. :2cents:
Nothing other than my vehicles and equipment will cross it. It’s 1/4 mile into my property on a UTV trail.
/ Structural engineers needed for a beam calculation. #37
Most larger vehicles weigh more than 4,000#. A PE will most likely do what you tell them to do regarding a design based on specified load ratings. I got involved once when a truck collapsed the bridge getting to an island in the Menominee River. He narrowly escaped death. The bridge was clearly marked with the load rating, but he went for it anyway not thinking. Go yoose Huskies!! MTU 1986.
/ Structural engineers needed for a beam calculation. #38
The PE told us we didn't have a choice and followed state guide lines. The structure needed states DNR stamp of approval. No fire trucks. I should add that I can't recall what live weight he stated we need to include, it was basically one 3/4 truck, whatever they weight.
Boomless Sprayer (A64127)
Boomless Sprayer...
CATERPILLAR D4H CRAWLER DOZER (A64277)
CATERPILLAR D4H...
Concrete Mixer (A66408)
Concrete Mixer...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
