Stripped lug nut threads
/ Stripped lug nut threads #1
Dream Farmer
Western MN
Bobcat CT230
I have some lug bolts that are stripped due to end of bolt damaged. I want to run a tap through to repair any possible damage and get new bolts. Does anyone have the correct thread size for a CT230? I know they are 12mm but not sure if 1.25 or 1.5 threads
/ Stripped lug nut threads #2
Look and see if it will poke through unimpeded. My JD uses a certain length but they were had to get so I just got the next length up and they stuck through the hub a quarter inch. Not a problem. At least I can see if they are backing out at all.
/ Stripped lug nut threads #3
Take a good nut/bolt pair to your local dealer and go from there. I've never put much faith in stripped nut/bolt combo's - especially when dealing with wheel components.
/ Stripped lug nut threads #4
Fronts are 12mmx1.25, rears are 16mmx1.5
/ Stripped lug nut threads #5
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2022 EZ-GO ELITE...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2006 Ford F-250 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
Altec Digger Derrick Hydraulic Boom (A61573)
Altec Digger...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
