Stripped lug nut threads
/ Stripped lug nut threads #1
Dream Farmer
Member
Western MN
Bobcat CT230
I have some lug bolts that are stripped due to end of bolt damaged. I want to run a tap through to repair any possible damage and get new bolts. Does anyone have the correct thread size for a CT230? I know they are 12mm but not sure if 1.25 or 1.5 threads
/ Stripped lug nut threads #2
Look and see if it will poke through unimpeded. My JD uses a certain length but they were had to get so I just got the next length up and they stuck through the hub a quarter inch. Not a problem. At least I can see if they are backing out at all.
/ Stripped lug nut threads #3
Take a good nut/bolt pair to your local dealer and go from there. I've never put much faith in stripped nut/bolt combo's - especially when dealing with wheel components.
/ Stripped lug nut threads #4
Fronts are 12mmx1.25, rears are 16mmx1.5
/ Stripped lug nut threads #5
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
KUBOTA RTV 900 UTV (A64280)
KUBOTA RTV 900 UTV...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2016 INTERNATIONAL...
2017 Gehl RS6-34 (A64119)
2017 Gehl RS6-34...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
