Stream Crossings
   / Stream Crossings #11
Use your back or box blade to tow with,
chain of the blade with the ability to use the blade as a stop for what you are towing.
   / Stream Crossings #12
You've also got lots of trees on the way to the creek, so you could also winch the trailer bed down to the creek using the trees as anchor points. - with a pulley, you could also use the tractor as an offset puller to replace the winch.
   / Stream Crossings
Getting it across the stream would be a problem. Would need a winch with wire up over a high up pulley on the other side of the creek.
I used a little aluminum ramp made for ATVs as a cover over a culvert inlet to under my road years ago. Just made some tiers out of coffee cans filled with concrete to sit it on. Still there.
Ralph
International 574D Tractor (A50860)
International 574D...
3-Point Water Well Drill w/Drill Pipe (A50860)
3-Point Water Well...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
Gooseneck Trailer Hitch (A50860)
Gooseneck Trailer...
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
