stihl saw no start
   / stihl saw no start #1
tym233me
nebraska
JD 3025E
saw will not start on gas or small amount of either has spark at plug , and put new fuel in tank any ideas thanks .
   / stihl saw no start #2
Verify compression of 120psi or better and use new plug
   / stihl saw no start #3
^ +1
If you've already tried that, then how long has it been since it was used? Was it stored with fuel in it, or did you run it dry before storage? The ethanol blended fuel we are getting now is JUNK! I've bought more spark plugs this year than the last 10 years combined. :mad:
Also had to replace the priming bulb on a Stihl trimmer, and the fuel line on one of my saws.
   / stihl saw no start #4
I had to rebuild 3 carburetors in the past month due to storage with that **** ethanol fuel. From now on i only buy premium ethanol free fuel for my small engines, plus use blue marine grade fuel additive. I'm sick of this junk ruining my equipment. Our government SUCKS sometimes.
   / stihl saw no start #5
Preach on, Amen!
   / stihl saw no start #6
How strong is the spark?
   / stihl saw no start #7
did you try a new spark plug??? it did wonders to my mantis tiller
   / stihl saw no start #8
I am in the repair business and have NEVER seen this many bad carburetors in one summer! This corn goo has got to go, while it is good for my business, the downtime for guys trying to make a living with their small equipment is definitely taking it's toll.
   / stihl saw no start #9
probably the carburetor needs cleaning
   / stihl saw no start #10
You say it wont start on ether??
Try pulling the plug ad dumping about 1/2 of a soda cap full directly in there, if still no fire, it is probabally compression.
Saws wear out. If compression is not 120 or better it is time for a rebuild. And if it is below 100, it wont even fire with gas dumped straight in
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2015 Peterbilt 348 T/A Fuel Lube Truck (A50323)
2015 Peterbilt 348...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
