stihl saw no start
   / stihl saw no start #11
I had a similar problem with my Stihl MS170. Turns out that the fuel line to the fuel pickup in the tank was split in a nearly impossible to notice spot. Less than $5 for a new line and I was back in business.
   / stihl saw no start #12
I don't know what size saw you are trying to start but if it has a compression release, Try starting it without releasing compression. None of my Stihl saws like the compression release. Take out the plug and mix a little WD40 with gas and dribble a little bit in the cyllinder. Quickly replace the plug and it has to fire at least for a second or two. If not, The gas just ran down past your rings and you need a rebuild..
   / stihl saw no start #13
I fixed my Dad's saw a while back. He hardly ever uses it. So I go to bring it home, and he saws how it ran fine when he used it not too long ago.... Kinda like the car and tractor ad's "ran when parked"!
So, I get it home. Fill it up with fresh premium Husky mix and Premium gas. It will not even try to start; this saw always started in a couple pulls. Great spark... Put a bit of gas in the cylinder and it fires immediately, for a second.
While I'm doing this, I hear something rattle, so I shake the saw. Sounds like something in the gas tank! I drain it in to a coffee can, and plunk out comes the fuel filter with a piece of rotted hose! The hose was just mush!
Fortunately, there are three dealers withing a few minutes of here. Got a new hose and filter, put it on, and three pulls later running like a champ.
That was on an older Stihl 024AV. I have had to replace hoses on a Husky brush cutter and Husky backpack blower too. Sucky gas...
FWIW, that is one of my all time favorite saws. The Stihl 024/0260/260 series is a great, well balanced saw.
thanks for the help cleaned carb did not help found it had no spark really my helper thought he saw a spark ,the problem was ths choke lever got mis algined and was allways grounding out but moved the butterfly , thanks for the help guys
Case Titan 3530 (A56438)
Case Titan 3530...
Kivel Trailer Mover (A57149)
Kivel Trailer...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58216)
2015 CATERPILLAR...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
